206 SW rear trailing arms adjustment
    Mar 2017
    Sweden
    13
    Default 206 SW rear trailing arms adjustment
    I've changed the rear trailing arm bearings on a 206 SW MY2005 I've bought for a spottstyver as we say in Sweden. (Spottstyver equals bargain). I thougth I did this right but I didn't. When I lowered the car after I've gotten a lowrider. My question is, how do I raise the rear of my car? Are there any "rules" for how to do this?
    //Thomas
    Avisford NSW
    508
    You probably didn't mark the torsion bar locations and have set it up incorrectly.
    Mar 2017
    Sweden
    13
    Quote Originally Posted by ianrobbo View Post
    Yes I did. However, the chap I bought it from had probably made a try on this already because the torx-bolts at the end of the torsion bars where missing when I started.
    My question still remains though, is there some kind of guide on how to do this or is it a trail and error thing?
    842
    It's basically the same as this https://www.pug306.net/index.php?pageid=lowering
    Getting it to the correct height is trial and error, unless you have the Peugeot manual with reference lengths and a dummy damper.
    The good news, is once you've done it once or twice, it's pretty easy to keep trying spline positions until it's right, then put it all back together.
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Mar 2017
    Sweden
    13
    And, after some trial-and-error I finally got it right. Thx for your help.
