505 vented front rotors plus rear drum/disc upgrade
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By Bob D
  • 1 Post By Bruce Llewellyn
Thread: 505 vented front rotors plus rear drum/disc upgrade
    71
    Default 505 vented front rotors plus rear drum/disc upgrade
    I want to upgrade the brakes on our 1984 505 wagon (planned V6 engine upgrade). Vented front rotors are available for the 505, but what calipers do I use? The vented rotor is 7.5mm thicker than the solid rotor. Did the later GTI wagons use the vented rotors? Our car has the Teves front brakes.
    Second question - I want to change the rear brakes from drums to discs. Can the discs be adapted on to my existing rear axle or do I need to change the whole rear axle?
    Feb 2013
    israel
    815
    the rear axle is the same, just the hub carrier is different.
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    604
    I would say that the GTi does have vented discs
    Peujohn could confirm since he bought GTi struts at some point.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Our most Southern Member (Tas)
    254
    Our GTis dont have vented discs.
    Wrecking yards in USA have 505 vented discs as they came with the turbo motor we dont have here.
    604 caliper mounts ?
    Peter Chisholm likes this.
    8,696
    604 brakes much easier to get in this country. Don't bother with discs on the rear, the car won't be much quicker with the V6.
    1000+ Posts Beano's Avatar
    2,758
    I second that about the rear brakes. The rear drums actually operate very well.
    Oct 2011
    Toowoomba
    618
    604 front brakes bolt on, but the 604 has larger wheel studs. If you stick with the rear drums the handbrake gives a lot less trouble than it can with disks.
    Dano likes this.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    492
    Quote Originally Posted by Bruce Llewellyn View Post
    The wheel studs are interchangeable between the 12mm 504/5 studs and the 14mm 604 studs , just knock them out with a hammer and use a wheel nut and spacer to seat the new stud.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Peugeot 307 Wagon
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    8,696
    Also, a lot of work to fit rear discs to a live axle car.
    Feb 2001
    Romsey, Victoria, Australia
    4,661
    I've got a set of vented discs and calipers off a 604 already mounted on a 505 hub I was going to use on a v6 project but that'll never happen now.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
