The 504 wagon is running very nicely but does seem to have a bit of engine wobble when it is idling, I climbed under the other day and jamed the big screw driver up betwwen the body and the gear box, without exerting to much effort I could induce quite a bit of movement around the rear mount, should there be play at this point and if so how much is to much ?The two front mounts look almost new I would summise that they were replaced not long before I purchased the vehicle. The next question, if it does need replacing, would be availability of the required part? If I go to the trouble of replacing it I would prefer to do so with a new part not a second hand one. regards cane toad.
