504 GR/SR dashboard removal
Results 1 to 10 of 10
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    557
    Default 504 GR/SR dashboard removal
    G'day Froggers
    Would anyone have any experience removing the GR/SR dashboard ?
    I am looking to repair the blower motor as well as fixing the flap (I have hot air seeping in all the time) but I am afraid of breaking something.
    Advice is much appreciated
    Thank you
    504 GR/SR dashboard removal-dashboard.jpg
    Attached Thumbnails Attached Thumbnails 504 GR/SR dashboard removal-504-gr-sr-dashboard.jpg
    Cairo, Egypt
    557
    Bump
    Anyone ?
    504 GR/SR dashboard removal-13139309_1013777892037588_5654626057950119516_n.jpg
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Avisford NSW
    371
    The heater is located under the dash and can be removed without taking out the dash itself.
    Remove the centre console and it becomes pretty obvious.
    1000+ Posts Beano's Avatar
    2,411
    Hi Chadi,
    I think you did not get many replies here because your second photo looks so much like a 505 dash.
    Perhaps people were confused by this and didn't want to give you wrong advice ? Your cars over there are sometimes a bit different from ours.
    However as Ianrobbo has said, once you take out the centre console (in front of the gearstick) you should be able to see what needs to be done.
    Cairo, Egypt
    557
    Quote Originally Posted by ianrobbo View Post
    I had removed the center console a few times in the past (cleaning purposes) but I cannot remember seeing the heater(or feeling that I have liberal access); but I'll surely give it a try, since this won't be different between different dashboard models.
    Quote Originally Posted by Beano View Post
    Hi Chadi,
    The dashboard is typical GR/SR (late models from 1979 to 1983). I guess you guys only got the GL (maybe L too) and that's why it looks strange to you.
    Anyways I'll take the center console out, take a few pics and re-ask for help
    Chadi
    All since new
    SWOTR
    2,966
    Not that I'm an expert but out of all the 504s I've seen in Australia I've never seen a dashboard like the one in your picture. I have a 1980 504 sedan and it doesn't have your dashboard, it has the earlier one.
    Feb 2013
    israel
    796
    From 1979 the dash was changed unfortunately to the one in the photos, maybe your car is a 1978 and was stored couple of years.
    SWOTR
    2,966
    No, my 504 was manufactured (assembled) by Renault Australia in Heidelberg, Victoria in October 1980.
    Others will probably be a better source of information but my understanding is that Australian assembled 504s are not necessarily the same as those built in France etc. That is more than likely the reason why no one has been able to give you advice on the repairs you're wishing to undertake - we didn't get 504s with that dash. Except for 504 station wagons, we also didn't get 504s with a live rear axle and there may well be other differences too.
    Member pugmachine's Avatar
    Feb 2005
    NSW
    69
    Quote Originally Posted by Doush_504 View Post
    G'day Froggers
    Thank you
Name:	The dashboard.jpg
    Hi, I have a 1987 504 pickup with the same dash, remove the 3 cover strips in the middle of the dash
    with care as the clips are part of the cover and you will find 10mm bolts to undo, lower the steering
    and will be able to move the dash around but the blower is in the centre unit above the gearbox tunnel.
    It looks like the pickup's have no centre console.
    2,411
    ^ Must be an imported model.
    Years ago, I drove a friend's light blue 504 which had a live rear axle and drum brakes. It was imported from South Africa.
    It had a sweet gearbox and an 1800 engine with a carby that looked like it belonged on a lawnmower. Unfortunately the acceleration was very poor.
