406 Hdi with the shakes!
Results 1 to 17 of 17
    96
    Icon5 406 Hdi with the shakes!
    I have a 2003 406HDi, 380,000km. It is running like clockwork on my country road runs however I have been to Melb today (300 km drive) then hit stop start traffic on the Toll Way. The car developed significant shakes i.e. shaking the car, when idling in traffic. The tacho did not really fluctuate and if I lifted the engine speed to 1000rpm the shakes stopped. On getting home tonight I have let the car rest for a few hours and started it again - some vibration but not as significant. I have felt this before but no where near as bad as this morning. This is not just an engine vibration, it is something that makes the whole car shake. Any ideas where I start looking please?
    Glenn
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,582
    Quote Originally Posted by Glenn View Post
    Glenn
    I'm not sure but looking at the age of the car and the number of Km's on it I would look at engine and gearbox mounts, could have gone soft or even broken.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    WLB
    WLB is offline
    1000+ Posts WLB's Avatar
    Warragul, Vic.
    1,011
    Broken (missing) fan blade?
    I've had this happen with a belt-driven fan on a Range Rover, and it was enough to shake something that heavy. It happened in the Burnley tunnel in peak hour years ago. Very convenient, and there was a limit to how fast I could drive it to get out and off the freeway because the faster I went the worse it got. I had guessed what the problem was as I heard the plastic blade hit the underside of the bonnet.
    BUT, if the 406 only has electric fans (my recollection), then the faster you go, the more cooling air through the radiator, and the fans will turn off. Vibration stops.
    96
    Thanks guys. I checked the fan because I do know that it can cause a serious vibration but the blade is certainly all in one piece. Although engine mounts could be soft or broken something else would have to be out of balance to cause such a vibration in the first place. Thanks for your ideas.
    Glenn
    8,248
    ..... Although engine mounts could be soft or broken something else would have to be out of balance to cause such a vibration in the first place. Thanks for your ideas.
    Glenn
    Yes.... its called a diesel engine.
    A dud mount or two can cause a significant wobble.
    WLB
    WLB is offline
    Warragul, Vic.
    1,011
    Quote Originally Posted by WLB View Post
    ... BUT, if the 406 only has electric fans (my recollection), ....
    Doh!! As Homer Simpson would say!
    Of course the 406 doesn't have a mechanical fan! It's got a transverse engine! (And it isn't a 204 or 304)
    Note to self: Engage brain before replying to a post. (I daren't mention that I owned a 406 SRDT for years and my son has 2001 HDi)
    Sep 2003
    North Parramatta
    3,922
    Perhaps the alternator overriding pulley is giving up the ghost.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    292
    Check the harmonic balancer.
    1000+ Posts N5GTi6's Avatar
    1,074
    Is the car manual or auto - DMF on the way out ?
    but my money is on engine mounts.....
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    Fellow Frogger! Balki's Avatar
    Ulverstone/Tasmania
    606
    sounds like an injector has gone crook, i replaced a few in customers cars of late, they seem to be getting old
    2016 Cactus
    2003 Range rover l322
    1974 D special
    1971 D special
    1992 CX TGE Safari
    1961 ID19
    1972 DS21 Safari
    1965 Renault R4
    1923 Citroen B2
    1927 B14
    Massey ferguson 550
    Sep 2017
    yea
    19
    Agreed with balki, check injectors. You can also open fuel filter housing, drain and replace filter and refill housing with good quality injector cleaner and run car, see if this changes the old girl.
    You Also check for metal flakes in bottom, shows pump is worn.
    Good luck
    96
    Thanks everyone - you have given me a few more things to explore over the weekend.
    Glenn
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    346
    I've seen soft engine mount's cause significant vibration. I'm talking the entire car visibly moving.
    I wouldn't discount the engine mount's being the problem.
    As to why it would be worse in traffic, I'd say the extra heat from the environment and minimal to no air flow though the engine bay exaggerating the problem. Also if the A\C was on, the extra load on the engine could contribute to it too.
    96
    Thanks for the replies everyone. Took the car to "local" dealer today for a diagnostic check. Apparently there is an electrical problem either in the wiring harness for the fuel pump or the fuel pump itself. It looks like those that said fuel issues where on the money.
    Glenn
    Jan 2011
    60
    Has this been fixed? Do you have more detail on the actual repair & what they found?
    Glenn
    96
    Default shakey 406
    Quote Originally Posted by Farmpug View Post
    This has not been fixed yet. Basically dealer cleared the codes and said wit for it to happen again. I am still very suspicious that it is i9s associated with moisture on the crank sensor. This idea came from the UK 406 forum and it makes sense in that the day this happened it had been bucketing with rain.
    Glenn
    1,074
    Glenn
    Did the dealer actually take a look at the car ? Or did they just plug in the diagnostics and rely on that ?
    I'm amazed at the new age reliance on what the computer tells them about the engine, rather than the old school process of opening the bonnet and actually having a look at the engine.
    This must be very frustrating given that it's been going on for 2 months now.
    Justin
    '07 C3 Exclusive
