Bleeding abs brakes on a 406 coupe(brembo big brakes)
Like Tree2Likes
  • 1 Post By speaksgeek
Thread: Bleeding abs brakes on a 406 coupe(brembo big brakes)
    May 2017
    Box Hill nth
    67
    Default Bleeding abs brakes on a 406 coupe(brembo big brakes)
    is bleeding abs brakes as straight ahead as standard types.?
    I've never done it on abs brakes before but have done it on my old 205,504,405
    i just want to flush the system through with new fluid ,the pedal is a bit spongy (not a great deal) and a bleed fixed it on my last vehicles.
    money is very tight atm so I'm gonna have a go myself.
    i know the procedure but any tips would be good
    ta
    Bazz
    743
    Basically the same. You're "supposed" to cycle the abs unit using pp2000 after you bleed as normal.
    if you don't drain it, and only push new fluid through, then you should be fine. I've done it that way a bunch of times.
    Roland likes this.
    206 GTi 180 - Cat Cams, Remapped Group N ECU, AST Camber Tops & Coilovers, -2deg fixed camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Yokohama A050, PeugeotSport Baffled Sump, Powerflex Engine Mounts & Bushings, Setrab Oil cooler, Quaife diff, Velo seats.
    Sandown - 1:31.5
    Winton - 1:45.6
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Fellow Frogger! Roland's Avatar
    Perth
    671
    I agree with Speaksgeek.
    Just bleed them as per normal.
    Roland
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    406 SV Sedan D8 - Manual (1998)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    743
    Just to expand on my previous answer (was using phone).
    There is a process to cycle and bleed the ABS pump using PP2000 software. It's important to use if you let the brakes empty out, and introduce air in the pump.
    If you just bleed by pushing new fluid after the old fluid (the traditional way), then you shouldn't need to do this. If you get any air into the lines, then you will need the computer.
    Roland likes this.
    Sandown - 1:31.5
    Winton - 1:45.6
