306 gti6 inlet cam
  • 1 Post By PeterT
Thread: 306 gti6 inlet cam
    south australia
    220
    Default 306 gti6 inlet cam
    hi guys does anyone have a inlet camshaft gear off a 306 gti 6 for sale.it has to be a xu10j4rs motor.
    thanks stuart.
    Fellow Frogger! ducksonetime's Avatar
    165
    If you're after a pulley I have a pair off an XU10J4. I think they're the same except the RS ones are vernier pulleys (at least the ones in my GTi-6 are). I'm sure someone will correct me if I'm wrong, also you'd better double check the timing is the same.
    Current rides:
    '99 Honda VFR800 (daily)
    '02 Ducati 998 (weekender)
    Current Project:
    405 Mi16 2.045L
    http://goo.gl/ha5jLL
    Past rides:
    156 GTA
    https://youtu.be/HmKwwCwGrVg
    https://youtu.be/y-kgE4HyWzk
    306 GTi6
    405 Mi16
    Series 5 RX-7 TurboII
    E30 325i
    south australia
    220
    Quote Originally Posted by ducksonetime View Post
    im going to get a standard non vernier gear and see if the dimensions are the same.if so ill fit that.the vernier is really only to tweak the belt tension.
    7,214
    Quote Originally Posted by charles View Post
    ithe vernier is really only to tweak the belt tension.
    No, the vernier is to tweak the cam timing.
    ducksonetime likes this.
    165
    Yeah vernier is for cam timing, there is a tensioner to adjust belt tension.
    Also, sorry to be that guy, but it's a pulley -- gears are driven by other gears, pulleys are driven by belts.
    Anyway, if you're going to go for a non-adjustable pulley you need to check the key is in the right spot for RS cam to be timed correctly.
    Sent from my BBB100-2 using aussiefrogs mobile app
    Current rides:
    Current Project:
    405 Mi16 2.045L
    Past rides:
    156 GTA
    306 GTi6
    405 Mi16
    E30 325i
