Diagbox pp2000 driving me mad.
Results 1 to 18 of 18
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    Default Diagbox pp2000 driving me mad.
    I have a lexia cable set and diagbox/pp2000 s/w that I bought years back from eBay. I used it a few times on my 206GTi, but it has been sitting in the garage unused until today when I tried to diagnose issues with my daughters 2002 307 1.6 auto.
    The WinXP netbook I run it on is not that great, but does work (slowly).
    Diagbox version 7.02, pp2000 shows as 600.49.
    the Lexia interface shows as serial 921815 C/
    I have a 7 digit DAM - '0916389'
    When I start the program, it wants me to identify the vehicle type. I have a choice of 307VAN or 307CAN.
    If I enter 307CAN, it wants me to enter the VIN and then doesn't seem to talk to the ECU.
    If I enter 307VAN, it then asks for the DAM and fails to talk to most of the ECUs, but can connect to the engine and transmission ECU. Error is 'The ECU has not replied'
    I have tried entering the DAM as '09163' and '91638' neither work.
    It seems others have had this issue, but there is no clear answer - sometimes an old version lexia interface is blamed, sometimes the thread just dies. If anyone can confirm that I am entering the DAM correctly and whether diagbox 7.02 should work with a 2002 307 it would be good. I can upgrade to newer software, but would prefer not to unless it is really necessary.
    734
    Try just using 0000 as the dam, my 206 doesn't have a sticker with the DAM, and I watched a Peugeot dealer do that once, so it's what I do as well.
    My first lexia didn't work on the 206, no matter what the settings I used, the second one I bought works well.
    206 GTi 180 - Cat Cams, Remapped Group N ECU, AST Camber Tops & Coilovers, -2deg fixed camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Yokohama A050, PeugeotSport Baffled Sump, Powerflex Engine Mounts & Bushings, Setrab Oil cooler, Quaife diff, Velo seats.
    Sandown - 1:31.5
    Winton - 1:45.6
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    Quote Originally Posted by speaksgeek View Post
    Did you try the first one on other vehicles?
    734
    No, didn't get a chance.
    I read there are some with firmware that doesn't support 206 and 307 properly.
    Sandown - 1:31.5
    Winton - 1:45.6
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    Thanks speaksgeek. Yeah, I have read about issues with 307, but also read that this doesn't apply if you have version C along with right diagbox (and mine seems to be a good version). Nobody seems to be able to give a clear answer and a lot of people just give up posting on their threads after a while so it is hard to know if they ever get it working. There are a lot of different factors and the s/w is clearly not that reliable (many different versions suggest a lot of fixes and enhancements).
    Good news is I fixed the overheating problem, but I'll keep tinkering - next step will be to upgrade the diagbox s/w and try again next time daughter lets me near her car.
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    I am back to tinkering with diagbox again.
    Tried to upgrade my software from 7.02 yesterday and this morning.
    I have a whole set of files, and instructions on how to upgrade, using multiple steps from 7.02 to 7.57.
    Failed at the first hurdle unfortunately.
    I ran the file Diagbox Update V7.02 to V7.06
    It seemed to install and restarted the machine. The diagbox software still claims to be V7.02 though.
    Anyone know what I did wrong, or where I can download a file that does the upgrade in a single step (download.qclt.com doesn't exist any more)?
    The machine I am using for diags is an old netbook running WinXP.
    Member mandc's Avatar
    Gold Coast
    65
    Tried this myself today. I think you have to do each update separately..it's really a slow procedure. Make sure diagbox is closed...do update then restart...open diagbox and it should start the 'internet update' (even though you have the internet disabled). It should then restart as the updated diagbox. Then repeat this for each update. That part worked fine and I eventually got to 7.82.
    I have one file that goes from 7.xx to 7.57 (the original install was 7.02 with my download)
    It took me about 3 hours all up and at the end it still would not connect and was locking up, as well as being in French. Now about to do it all again on a XP laptop (was on win 7 32bit) to see if that makes it friendlier
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    I tried as you did but the version number did not change.
    I have tracked down a 7.XX to 7.44 update on the disc that came with my cable. Will give that a go.
    Did you copy the appdiag.sys file from 7.02 before upgrading?
    Gold Coast
    65
    Quote Originally Posted by UNM View Post
    No I didn't..maybe that's why mine did not go so well...I'll remember that when I reinstall..Thanks
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    I completed the initial 7.xx to 7.44 install and it gave an error (02 I think). I put back the original appdiag.sys and on the next start of diagbox it told me it was 'installing internet update. please wait'. Been waiting nearly an hour and the blue progress bar is sitting stationary as if complete. Will leave it for a while as the netbook is slow and it might be waiting on multiple net timeouts.
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    the 7.44 upgrade finally completed.
    It seems less than stable as it sometimes gives an error, sometimes starts OK.
    I still cannot get it working properly with the 2002 307 1.6l petrol.
    It talks to the engine, ABS and Auto ECUs, but not to any of the others, just get 'The ECU has not replied', which has been the problem since I first used it.
    I used to have a 206GTi and it worked fine with that.
    I shall continue updating the software as I have updates to take it to V7.61. Perhaps one of the newer versions will work better.
    According to the PSA interface checker, my lexia is:
    "APPLI_XS_Fuji_P106138A V4.3.2 @ACTIA 03.01.14"
    Reference: "921815 C/"
    AFAIK that is good enough to work with 307's
    Jul 2013
    Maitland NSW
    46
    UNM,
    where are you located? I have PP2000 running under a virtual machine and it's working well with my 2005 307 - I'm near Newcastle and might be able to help.
    Ewan
    Fellow Frogger! N5GTi6's Avatar
    976
    Could be any number of issues. Have a look at the following link which shows the changeover of OBDII protocols in use around that time :
    1.6 Petrol certainly changed.
    Peugeot OBD II diagnostic connector pinout diagram @ pinoutguide.com
    Justin
    '07 Megane R26
    '07 C3 Exclusive
    '09 308 XSE Touring
    '10 308 Sportium Touring
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    I am in Melbourne - outer East. I am pretty much certain the car is fine and it is an issue with my pp2000 or the cable pinout.
    If anyone has a clean install CD, I'd happily pay for a copy to be cut/sent to me just to eliminate the software as a possible failure point.
    Or a pointer to a download site for a relatively recent diagbox that is compatible with my cable set.
    So dukbilt1 - are you also called Ewan? Not many of us around.
    Gold Coast
    65
    As I've been flat out this week I haven't yet installed the diagbox to my recently reformatted laptop that now has XP on it. Re-reading your earlier post makes me wonder if your problem is the interface hardware and maybe not the software.
    I have recently purchased a connector and found 2 types on sale..the so called "Full chip" version and a cheaper one that has fewer chips in it. The full chip version is apparently needed for the 307. This is a current ad for a full chip connector that specifically mentions the 307:
    https://www.ebay.com/itm/PROXIA-Lexi...-/302149231589
    'Description
    PP2000/LEXIA-3 Interface latest version, Full Chip REV C, works for both Citroen and Peugeot! It
    does work fine with the 307 and C4,C5.'
    I know you mentioned that you have Version C hardware but I'm not sure if that automatically means it is full chip....maybe worth checking.
    Jan 2018
    4
    Quote Originally Posted by mandc View Post
    'Description
    I bought from these guys Lexia-3 Lexia3 V48 PP2000 V25 with Diagbox V7.76 the instructions for diagbox install & update mentioned to install on window 7 equipped OS I have completed install and all works great, I have full access to everything on my 508gt
    Gold Coast
    65
    Finally got it to partially talk to the 406 today..still no connection to the engine ecu but was able to remove some error codes from the electric seats/ exterior mirrors and the a/c ecu with the global test. Oh well...It's a start.
    UNM
    UNM is offline
    Dec 2014
    Australia
    260
    'Description
    I opened up my Lexia and U5, U6, U7, U9 chips seem to be missing on mine. Look like optocouplers to me (not that I am an expert).
    You might be right about the cable being the problem.
    Can anyone with more knowledge comment on this?
