Cals Cars - Page 5
Page 5 of 6 First 123456 Last
Results 101 to 125 of 126
Like Tree66Likes
Thread: Cals Cars
  1. #101
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,038
    Default Cals Cars
    Hi Cal,
    A very enjoyable read, thanks for the update on all your endeavours. I must say it’s excellent to see stories of road going adventures. Keep it coming
    cheers
    Craig
  2. #102
    1000+ Posts Isis's Avatar
    1,100
    Yeah great read Cal and good to see some real fun going on. I need to come over when you get the Mi back and get that Si rack off you.
    Ash
    Codman likes this.
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
  3. #103
    Fellow Frogger! Codman's Avatar
    Feb 2015
    Skye, Victoria
    518
    Got back on the 404 this afternoon for a couple hours after work.
    I got a good rear end a little while back and had a look at options this evening, I was hoping to just swap across the brakes, but it seems it is from a later model and is larger, it also has what looks to be a bias valve that my car does not.
    Wondering now weather to swap across the whole axle, or just the brakes.
    While I was at it, I have pulled a stub axle to see how it all goes together, the bearing is tight and good but there was oil leaking out, I assume the bearing needs to come away to change the shaft seal? And are they still available?
    Sent from my HUAWEI RIO-L02 using Tapatalk
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 505 Custom Turbo Wagon
    92' 205 SI
    88' 505 GTI Wagon - PARTING OUT PM ME
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  4. #104
    9,019
    The diff won't fit your car, the bolt spacing and size on the front is wrong for your torque tube. Do you have the torque tube that comes with the new diff? You can buy axle seals anywhere, need to pull the bearing off with a puller , also replace the shrink ring. Doesn't look too bad maybe just clean up, there is a special hole for oil to escape. I may have a late torque tube available or even an early diff although they probably went with the 403 parts clean out. 203 clean out happens now that the 203 has gone, will now just concentrate on the 404 for my early car.
  5. #105
    Feb 2015
    Skye, Victoria
    518
    No tube for the new diff, though my original one seems to be fine anyways.
    Back to sourcing wheel cylinders and using all the original rear end, must need a unique puller to get the bearing off? i hate to pull it all apart but the seal is leaking pretty badly.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  6. #106
    Fellow Frogger! cam740's Avatar
    Apr 2005
    Southern Beaches SA
    867
    Couldn't sleep last night so at 130am i was reading the thread, well done, really looking forward to hearing more about the turbo 505 wagon, sounds like a right sleeper!
  7. #107
    Feb 2015
    Skye, Victoria
    518
    A couple of little teasers, both have had little hold ups but stoked to see the 205 back on its wheels and the 505 officially turbocharged
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  8. #108
    1000+ Posts Beano's Avatar
    2,933
    I love that clean look of no oil leaks in the 505 !
  9. #109
    Lilydale, Melbourne
    2,091
    Nice work... I have been wondering what thoughts Bill has to offer on the Douvrin, now that he has built a hot one.
    Sent from my SM-G900I using Tapatalk
    John W
    1974 Peugeot 504 TI
    - now on the road
  10. #110
    Mar 2015
    Tooradin Victoria
    229
    Not as much as I do Beano.............'Cecil' my '84 STi seems to specialise in them despite new gaskets hither & yon. Would love to have Cal's hardware under the bonnet!
    Beano likes this.
  11. #111
    2,933
    Ya gotta track em down and kill em, dude !
    Degrease and find some, then fix.
    When more oil appears, degrease again and after driving a day or two, look with a torch at night....it reveals much more than during day.
    Using gasket-grade silicone with every gasket helps, too.
  12. #112
    Feb 2015
    Skye, Victoria
    518
    Well!
    A good couple of months have been had, a few weeks back, my brother Sean and I toured up to Sydney to the French car day and met with my 205GTI again after a little time apart. We had a fantastic day and where able to put plenty of faces to names and can not stress how welcoming and friendly you northern folks are, a massive thank you to all who took the time to say hello and have a chat.
    The 205 commanded interest and the was rarely time for myself to get around it!
    It took the award for best modified Peugeot, and what a way to kick of its rebirth!
    Cals Cars-p1000268.jpgCals Cars-p1000283.jpgCals Cars-p1000285.jpgCals Cars-img_20180716_143918.jpg
    I will be taking it to the Haunted Hills hill-climb next weekend for its first outing and will be sure to get some video of it,not for any spectacular driving demonstration, but for the noise!
    The little SI has lived through yet another rally, the HRA Magical Ironbark Tour, I managed to convince my good friend Harry to sit in the smart seat, whilst we didnt do the car, nor the event justice, we did have an absolute blast!
    The navigation was frankly beyond us, understandably given our severe lack of experience, but there where some fantastic roads, and two closed sections really gave me a chance to punish the little car, huge thanks to all that made it happen, and to Harry for battling the instructions no matter how frustrating.
    Api also got out there in the 405 and got it sideways at every chance!, Graham W too
    Sean maned the camera and gave us a few shots
    Cals Cars-p1000728.jpg Cals Cars-p1000381.jpgCals Cars-37655367_1988005921512116_6974548201713958912_o.jpgCals Cars-37583674_1988004831512225_6914275869087236096_o.jpg
    I have also collected Graham W's ex Rally 205 to rebuild to have a play in the AUS-RX series
    BIGRR, CEyssens, Richard W and 1 others like this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  13. #113
    9,019
    205 maxis old trailer still getting a workout. This trailer was built in 1975, what stories it could tell. We will get the old rally car going with the old stock Si motor out of my club sport car, was a bit smoky, but will run well enough to give RX a try out in November. I will be entering a 405 Mi16 in the new RX2 class for cars without cages, two cars at a time, not 6.
  14. #114
    Feb 2015
    Skye, Victoria
    518
    A few more
    ianrobbo, FIVEDOOR and bowie like this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  15. #115
    1000+ Posts Richard W's Avatar
    May 2012
    1,328
    Default Cals Cars
    That's pretty much identical max power and torque to mine on the same dyno - I got 110.6kw or 148.3hp with Peter T's stage 1 cams and standard throttle body and about 11.5:1 static CR. However your torque curve is fatter in the midrange - you look to be almost 10hp up on me at 4500rpm!
    What did you end up doing to your engine?
  16. #116
    9,019
    MUCH better than my 1.9 Mi16 with ITBs in midrange. Similar power at top end.
  17. #117
    Feb 2015
    Skye, Victoria
    518
    Peters stage 1 cams, and Huws 42mm ITB set-up still running more or less standard compression.
    I think the TBs are having a fairly profound effect, and in combination with the light flywheel, response is insane.
    Quote Originally Posted by Richard W View Post
Name:	16valv new cams.jpg
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  18. #118
    Feb 2015
    Skye, Victoria
    518
    I'm not sure how keen I'd be on the ITBs for more of a street car, I think the fly magnifies it too.
    For interest sake I stuck it on the weigh bridge at work, 903KG with a half tank.
    My club SI is 800, so a 100kg penalty for the cage and what would be twice the power now of the 1.6
    michael_ozzie likes this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  19. #119
    Jan 2012
    Sunbury
    377
    Quote Originally Posted by Codman View Post
    Great to see it back, loving the look of the s1 dash switches. I tried to do the same thing, but I left the heater controls so it doesn’t look anywhere near as clean.
    Might have to get a bit more safety kit and see what this “rallycross” is about.
    Got something to bring out for Graham’s Autocross Tour late September?
    Michael
    1987 Peugeot 205 GTI
    Build Thread:
    http://www.aussiefrogs.com/forum/res...ti6-build.html
  20. #120
    Feb 2015
    Skye, Victoria
    518
    Had the hill climb today and threw together a couple of clips -
    https://youtu.be/alSC4mke5fQ
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  21. #121
    Feb 2015
    Skye, Victoria
    518
    Quote Originally Posted by michael_ozzie View Post
    I'm pretty convinced on losing the heater unit, its massive and de complicates. Though, I do have the heated screen.
    The White car will be there for sure!
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  22. #122
    Feb 2015
    Skye, Victoria
    518
    Things learnt from the day,
    Spare plugs, I missed the first few rounds as the plugs had fouled and I didn't have any spares, lucky there was a Repco in Moe 15 mins away.
    Throttle control is going to be a critical element to getting the best out of this car, it is extraordinarily responsive coming off the gas, I'm sure this will come with time.
    Way way more brakes, I was extraordinarily conservative, getting on the brakes and off the power way before I needed to.
    Seating position, Seat and peddles feel good but the wheel is floating up in the middle of nowhere, needs to come down, out and a smaller radius.
    All in all, both cars did very well, placing middle of the field, for our first time at Haunted Hills and being Sean and I's first tarmac event
    So now a bolt check and go over, and I'll be on the look out for some sprint days
    bowie likes this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  23. #123
    9,019
    How much quicker was the new car over the Si?
  24. #124
    Feb 2015
    Skye, Victoria
    518
    A second and a Half on the short track, Red car 44:17 White 45:72.
    I'm not sure there was much left in the SI, but there was a hell of a lot to make up in the GTI, my times where dropping consistently throughout the day as i was getting familiar with it, as it was the first time really driving it.
    CEyssens and michael_ozzie like this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
  25. #125
    Feb 2015
    Skye, Victoria
    518
    With another few events coming up i have been back at it preparing the cars, yes, plural.
    Now that i am looking out for more tarmac stuff for the Red car, I figure i may as well bring along the White one, not sure what it is with that colour combo, Parry? Michael?
    So first up on the 22nd the HSCCV are hosting a sprint at Sandown, this will be a great event for us, the track is only a 20min drive from home and there are instructors available throughout the day which will be helpful.
    So the white car finally received its matching GTI rear end, gone is the old SI bars, mounts, arms and drums and in with solid mounts, full set of GTI bars, new seals, bearings, and 306 arms and disk brakes, a set of Billies Graham had on the self also have had some new brake lines made up to suit.
    Now back to where it was when I originally bought it, with a couple of extra nice bits.
    This car will be in GrahamW's Autocross tour the next weekend also, so its going to be a rough period for the little battler!
    Sean will be Navigating again, HOPEFULLY, he will be able to keep his stomach down, I've bought another openface brain bucket with an inbuilt headset and a intercom for the car, so it should be a little easier and less stressful in the car.
    The Red car is waiting for the hoist, over the weekend i'll give it a bolt check, a couple small things where picked up at scrutiny at the Hill climb, a + terminal cover, tow and battery markings so they will be done, also going to space down the wheel and put a dished smaller unit in to suit the seating position a little better.
    My Old Man has decided to bring along his own car, his C63 Merc, so cant wait to see the times between the 3 cars
    michael_ozzie and CEyssens like this.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 205 SI
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
