604 firing back
Thread: 604 firing back
    Hobart
    1,496
    604 firing back
    Hi,
    I have a 604 question....
    The car is timed correctly and points are fine and firing order is OK...and compression is fine *test has been done*
    But the car seems to fire back at around 3,000rpm...it idles fine and seems to have power but once taken up to 3,000rpm it fires back...
    Any thoughts ?
    I've tried leads already!
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    12,266
    what carb is on it ?
    how old are the plugs and what are they ?
    what gap are the plugs set at ?
    electric fuel pump fitted or standard pump ?
    how old is the exhaust and if a muffler has been replaced is it on the right way around ?
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Hobart
    1,496
    Sean,
    it has the Solex carbies on it, Bosch plugs *fairly new* gap of 20thou, standard fuel pump, yes the exhaust is fine...
    Ben
    1973 Peugeot 504 GL
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Sounds similar to symtoms I've struck when the fuel filter is getting past it's use by date.
    In carby engines, moisture in the carb particularly in Weber dual throat types will start to cause spluttering & backfiring as it gets around mid range before it goes onto the main jet. If you flatten the accellerator, does it get worse or just hesitate & then take off as normal?
    A bottle of fuel system cleaner wouldn't go astray.
    Alan S
    12,266
    Pug_405_Mi16:
    Sean,
    Ben
    check for vaccuum leaks everywhere
    sounds like a case of the second carb also may need a kit through it or just a damn good clean out
    2 bottles of fuel system cleaner in about 1/2-3/4 of a tank should do it and just drive it but it really sounds like the rear carb is playing up
    now we have that out of the way
    pics pics pics are needed of this new girl
    1 x 2018 3008
