307CC rear lights / fuses
    Apr 2011
    17
    Default 307CC rear lights / fuses
    On my 2008 307CC, the RH rear side lights (both boot-lid and fender mounted) and RH number plate light are not operating. As far as I can see, all other lights and electrical functions generally are working as normal. It is just the RH rear side lights and RH number plate light that are not working.
    The fuse lists in the handbook (pp105-109) do not show the fuses for these lights.
    Can anyone suggest which fuse/s might be the cause here? Alternatively, is there a connector that serves these lights that might be the cause?
    Does anyone have the complete fuse list for this model that does show the fuse for these functions?
    Failing that, any other ideas or suggestions?
    Many thanks for your help on this.
    Current: 2013 Citroen DS4, 2000 Xantia 2.0L
    Past: BX (x 2!), 504 Wagon,
    2008 307CC 2.0L Auto
    Jun 2017
    1
    Replace the number plate globe and the tail light will work.
    tweed heads
    1,396
    c heck the globes ,they may have blown independently over time and there failures are unrelated ,pugs
    Apr 2011
    17
    Well, I finally fixed my light problem. I have followed a most circuitous (sorry) path trying to determine the location of the F12 fuse (which I didn't ever find, btw) then proving that I did indeed have 12V at the black, 6-pin plug near the light, then going back to check the condition of the number plate light. Sure enough, the number plate globe was not seating properly so reseating it brought the whole system into life! Phew...
    It still amazes me that they would run the number plate globe in series with the rear light. A most incredible (and highly disappointing) instance of shoddy engineering.
    Anyway, many thanks for your various contributions here. I appreciate your input!
    Kim
