Graunchy 404 box
Like Tree6Likes
  • 1 Post By robmac
  • 1 Post By Peter Chisholm
  • 2 Post By robmac
  • 2 Post By GRAHAM WALLIS
Thread: Graunchy 404 box
    Nov 2013
    Arrowtown
    17
    Default Graunchy 404 box
    Hi, just started happening on my 1970 NZ assembled 404 manual. Can't get into reverse, and pretty notchy between gears. Is there any adjustment I can make?
    17,160
    Quote Originally Posted by Cookiemonster View Post
    How does the clutch pedal feel ?
    Clutch hydraulics failing are a typical reason for difficult gear selection.
    The 404 has no provision for adjusting the clutch.
    driven likes this.
    Mutual Respect is Contagious
    Nov 2013
    Arrowtown
    17
    Pedal feels a bit soft, I topped up the reservoir to max and that made a difference for a week or so.
    SWOTR
    3,086
    While you're at it, I'd check the gearbox oil level.
    Dano likes this.
    17,160
    Put on your mechanic's gloves and depress the little plunger in the centre of theclutch master cylinder reservoir, it's just under the fluid level.
    If you see a stream of bubbles (air) in the fluid, then there is good chance the clutch hydraulics need attention.
    Depressing the plunger will often "fix" the clutch for a few days.
    You can also check out if there is an air leak by inspecting the transparent nylon line between the master and slave cylinders. Look for air "slugs" in the line.
    Demannu and Dano like this.
    8,494
    While the plunger is depressed operate the rod that pushes the piston in the cylinder. No need to put your foot on the pedal just lift the rod with your finger. There will be a rush of bubbles as the cylinder bleeds itself, clutch should then be OK for a while.
    Wildebeest and Dano like this.
