My 404C resto begins! - Page 3
Page 3 of 8 First 1234567 ... Last
Results 51 to 75 of 177
Like Tree274Likes
Thread: My 404C resto begins!
  1. #51
    Fellow Frogger! Dano's Avatar
    Apr 2012
    811
    Mike,
    It could be a little on the expensive side, but have you thought about getting one turned up at an engineering shop. If they used a mild steal round section of similar size, it would not be too difficult to hollow out and cut a thread...
    Dan
  2. #52
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,672
    I had thought of that Dan. Meanwhile, yesterday the guy who was putting the new Peugeot OE strut inserts together managed to turn down a 1963 style nut on a lathe to fit the 1966 strut. In the photo below, the strut on the left has the modified 1963 nut on it, which has closed it off well enough and the strut insert does not move. The one on the right is the original 1966 type. But if a "proper" 1966 version becomes available, I would rather use that.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
  3. #53
    Jan 2002
    1,672
    March 31st: major welding is all done. Next week it will be a full coating in epoxy primer, then a few weeks of blocking and priming, followed by a topcoat in Dark Blue 1057. Exciting times! Oh yeah that's me in photo 1, a bit older than the car.
  4. #54
    SWOTR
    3,342
    Mike, the car is coming along really well. I'll bet you can't wait till it's finished and you take it for a test drive.
    Mike Tippett likes this.
  5. #55
    Apr 2012
    811
    Looking great Mike.
  6. #56
    Jan 2012
    Gold Coast
    175
    So much great work that will never be seen once finished.
    Marty
  7. #57
    Jan 2002
    1,672
    Despite the flu today I made a short visit to the 404C. The shell has all been primed in epoxy and the interior bits have been painted in Dark Blue 1057 (Bleu Foncé 1057), mixed based upon a colour chip I have from 1966 sales material, with actual paint on it. Here is a shot of the engine compartment (the car was under plastic wrap when I stopped by the shop).
    For comparison, in similar lighting conditions, here is the Coupé of my friend Tim Bowles of Victoria BC, and he told me that when his car was repainted 25 years ago, it was a tone or half tone too light. Still lovely.
  8. #58
    SWOTR
    3,342
    Just beautiful Mike, and it's good to see what it will look like when completed. What's happening with the mechanical components?
  9. #59
    Apr 2012
    811
    Magnifique!! It may have been on hold for many years, but it is now all coming together.
  10. #60
    18,038
    Quote Originally Posted by Mike Tippett View Post
    Not to depreciate the wonderful rust repairs and paint.
    It seems to me that rear battery mount bracket is bent. I recall that they(on sedan anyway) were vertical.
    If I'm in fact correct , now is the time to fix it up , during paint, rather than afterwards.
    Please feel free to tell me to " faire chier" if I'm wrong.
    Congratulations on the work so far.
    with apologies to Judy Grahn
  11. #61
    Jan 2002
    1,672
    Quote Originally Posted by Peter Chisholm View Post
    I will take the gearbox soon to a transmission shop in Victoria BC to have the bearings and seals replaced. I will disassemble the engine around that time and start the work on it. I have new high compression pistons in an 0111.31 set from Peugeot but before reassembling it, the block needs to be be boiled out and painted, the crank sludge traps need to be removed and oiling channels cleared, crank inspected and ground if necessary. I have a brand new 8 port head but the valve seats must be replaced with hardened ones, so I will need to send that out around the same time.
    The suspension is totally rebuilt with new parts now, including new Peugeot front dampers. The braking system is Hydrovac and I have a NOS Hydrovac booster and rebuild kits for all cylinders, new brake hoses.
    The upholstery needs to be done too. Leather is incorrect for a Coupé but I am thinking I'll get light grey leather for the seats.
    Dano, Peter Chisholm and FIVEDOOR like this.
  12. #62
    Jan 2002
    1,672
    It is vertical, look at the back of the horizontal flange, that is where the tray is bolted to the bracket. The horizontal bit is used for something else.
  13. #63
    18,038
    Indeed correct. I'd completely overlooked the hex head self tapper securing the battery tray.
  14. #64
    Oct 2003
    canberra
    825
    Default coupe
    looking great Mike, a lovely color choice
  15. #65
    Jan 2002
    1,672
    There is not a lot to report on the bodyshell other than it has the anti gravel undercoat on it now.
    Friday afternoon I reassembled the struts, with new grease seals, new roller bearings for the steering swivels, new rubber boot and new upper cups. *That factory spring compressor is fantastic!
    Demannu and Gambo1 like this.
  16. #66
    Apr 2012
    811
    Mike,
    The proper spring compressors are the only way to go. They make it a lot easier and safer to remove and refit the springs. I've seen some very dodgy apparatuses being used. When a 404 spring lets go, you don't wont to be standing around.
    Dano
  17. #67
    Jan 2002
    1,672
    Work continues. Wow does the blue ever look dark when the car is in the shop! It's the same paint that you see in the engine compartment photo from a few weeks ago!
    Dano, Peter Chisholm and Gambo1 like this.
  18. #68
    Jan 2002
    1,672
  19. #69
    Jan 2002
    1,672
    June 2nd: the trim is being test fitted and the final body blocking is underway. Paint should be applied by the end of the next week: dark blue.
  20. #70
    Jan 2002
    1,672
    This week, Harry Kalsbeek sent me a most appreciated gift - exact replicas of the Kalsbeek Motors dealer sticker that were on all cars they sold from their Ontario dealership in the sixties. This will again be worn with pride on the back of my 404 Coupé - delivered to its first owner in BC by Harry's parents themselves, all the way from the Greater Toronto Area - once the car is delivered back to me. He also sent some Castrol oil change door jamb stickers printed with the dealership name.
  21. #71
    Jan 2002
    1,672
    This afternoon I decided to have a look inside the lever end of the Italian-made Nardi floor shifter that my 404C had from new. The last two I opened up had plastic bushings that had disintegrated over time and I thought that this one had a plastic bushing too, but intact, because the lever action was perfect.
    After removing the 4 screws below the shifter, there was some very old, dirty oil in there. This end of the shifter cannot get any lubrication from the gearbox proper even though it's attached to it. The other two 404 Nardi shifters I had in the past were dry in there, with just some grease on the moving parts....
    After removing two circlips, the mechanism comes apart. I could have removed the lever but decided against it because the bolt inside the mechanism is tied shut with a wire and it seemed very serene - I could clean around the lever, with it still somewhat attached.....
    The bushing in this version of the Nardi is definitely not plastic, it's bronze or brass! It's in great condition!
    View of the bronze bushing, which when the lever is actuated, moves up and down inside the sleeve attached to the shifter rod that transmits the action to the gearbox shifting forks.
    The sump has been drained and cleaned out, and the bronze bushing is again circlipsed into place.
    The sealing faces and threading of the little sump were carefully cleaned and then sealed with Hylomar Blue, to prevent any oil leaks.
    Sump screw on the Nardi, accessible from inside the car, 24 mm.
    ...and refilled with Yacco vegetable based differential oil!
  22. #72
    Jul 2004
    CLARE SA
    2,323
    Mike, impressed with your disavowal of traditional men's clothing colours. and envious, of course ...
    ed
  23. #73
    Jan 2002
    1,672
    Newly powder coated wheels, new door jamb sill plates, some minor parts:
    New XAS tires for the 4 rims and spare:
    Rebuilt pedal assembly:
    Disassembled grille:
  24. #74
    SWOTR
    3,342
    Great progress Mike and such a high standard. You do realise that there are many envious people out there?
  25. #75
    Jan 2002
    1,672
    Now, you're probably thinking: "Mike, when - for criminy sake - will your 404 be painted?" Well, I was asked to bring the grille surround back to the shop on Bastille Day to Coachwerks, as the bodyshell is virtually ready to paint. A final fitting of the grill surround to the shell will confirm that it's ready. Meanwhile, two of the three taillight bezels I have as well as the door handles are still at the chrome shop, as well as both bumpers, the latter for dent repair and polishing only.
    You've read this before, but it's possible that the car will be painted in a week's time, and almost certainly by the end of July.
    So, Peter Gallagher of Automotion, 1390 Pemberton Avenue North Vancouver, did the mounting and balancing when I was at his shop on Tuesday (11 July) morning. When I arrived he was nearly done, but I managed to catch the last bit of work. The wheels were "too pretty", Peter said, to hammer rim weights onto, so he used stick-on weights that will be invisible behind the large hubcaps.
    I think I will keep the two 30 year old Michelin MXL and two 28 year old XM+S 100 tires on rims, so when the car sits in the garage it can be on those tires, saving the XAS from flat-spotting during storage.
    Dano likes this.
