205 no mi16
Results 1 to 21 of 21
Thread: 205 no mi16
    Fellow Frogger! ruckus's Avatar
    Apr 2004
    491
    Default 205 no mi16
    Ok. After doing the sums on the Mi16 conversion for my 205 and the associated problems in Vic, I have decided to go the safe path.
    The conversion looked like it was going to cost anywhere from $4000 to $4,500, with no certainty that there wouldn't be later costs that i hadn't expected/didn't know of. So my situation now is:
    '88 205 Gti with cracked head from severe engine fry (this is how i got it after buying it from a friend after the heat guage stopped working).
    I am still prepared to put $3,500 - $4000 into the car so what do you guys think?
    A S3 engine is the only thing that I'm pretty sure about, so how much should I expect to pay?
    With the calculated money left what do you think should be done for the rest of the car?
    The clutch and box were just reworked before the trauma so that should be fine.
    Suspension and brakes top priority?
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Quote Originally Posted by ruckus
    Dude i suggest if you find an S3 engine that you should also go to the casino and put your $4000 on black.
    NSW
    1,063
    What Luca is trying to say is that your chances of finding a S3 engine are next to NIL.
    Why not just find another head and speak to PeterT about the head package that he and the Wuillemins have come up with. I've driven the final product and its a mile ahead of a standard 205.
    Apr 2004
    491
    I was a bit concerned over the extent of the engine damage. My friend had it looked at by some guys in Geelong and they said that it would be cheaper in the long run to replace the engine. I assumed from this that the heat stress could have effected other parts of the engine significantly.
    I won't know for sure until I get it looked at by someone with a bit more peugeot experience but I was just trying to figure out sums for the worst case scenario.
    Any idea how much the replacement head would cost from PeterT?
    7,483
    The 75kW pistons have a much shallower dish than the 90kW pistons. Whereas the 90kW head has a smaller chamber than the 75kW head. So ideally, if you're chasing compression, the 90kW head on a 75kW piston/block is the way to go. The only spare head I have is a 1.6L head (also nice small chambers like 90kW). I really didn't want to sell it, but if you offered the right money....?
    Mar 2003
    1,335
    Or get a big skim on the 75kw head to bring the comp up...
    Apr 2004
    491
    hmmmmm food for thought.
    I need to get the car in for a decent analysis so that I can figure out whether a head swap would be a feasible option. From what my uneducated brain can figure out you are suggesting that the 90kw head will result in an engine that is significantly improved on the stock S1?
    How much would I be looking at for the 90kw head? Is this going to be as elusive as the S3 engine or is it more within the bounds of possibility (all casino related probability jokes aside)?
    Mar 2003
    1,335
    The 90 kw head is from the S3 eng. therefore $4000 on black at the casino is looking good.
    Ipswich, Queensland.
    1,911
    I believe the later series 1 405 head is the same as the S3 205 head. You are much more likely to find one of these. There are date marks as part of the casting to pick them out. Also the chamber is about 3mm shallower than the low comp head. A '91 head with new pistons and sleeves and one of Peter Ts cams would certainly be less than $3000.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    02 and 03 Renault Clios 1.4L
    12,264
    what is the difference between an 8V 405 engine and the 8V 205 engine ???
    there are plenty of 405's around and if the parts fit use them
    i always thought that they are basically the same engine
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    and the BX Tzi 122 motor is the same. Should be heaps of these things around I woulda thought.
    So you need to find out in which way your motor is rooted.
    Best thing is to just get the existing head done.
    Aug 2002
    1,290
    There is a 405 90 model at pickles, could fit the bill perfectly.
    VEHICLE DETAILS
    Compliance Date
    01/90
    Make
    PEUGEOT
    Model
    405, Sedan
    Description
    WHITE, AUTOMATIC, 1.9 LTR, 4 cyl, UNLEADED, Multi-Point Injected
    Registration No
    No Registration
    Stock No
    3069394
    Odometer
    234,522 kms
    Registered Until
    No Registration
    Extras
    Aircond., P/Steer, Cassette, Radio, Jack, Alloy Wheels
    SALE DETAILS
    Proposed for sale
    MELBOURNE - TULLAMARINE: 04/05/2004
    Damaged Vehicles
    89 Garden Drive
    Tullamarine VIC 3043
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Apr 2004
    491
    Thanks for the help guys. Any theories at the moment are just speculation until i get the car in to someone i can trust who can tell me the real extent of the damage to the engine. I'll report back when I have a more concrete idea of the necessary future direction. Then we can all duke it out over what the best option would be
    Apr 2004
    491
    ...The only spare head I have is a 1.6L head (also nice small chambers like 90kW). I really didn't want to sell it, but if you offered the right money....?
    and what exactly might be the right money...any hints?
    Apr 2004
    491
    Default aaaaaaaaaarrrrrrggggggggghhhhhhhh
    nooooooooooooooooooooo.
    It's the block that's cracked not the head.
    7,483
    Just start looking for a 90kW 205/405 motor. Or, I have a spare block if you're interested.
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    546
    That sucks, but I can tell you know... 405 head on 205 engine = Yum. Lots of front-wheel spinning goodness
    -- DJ
    Mar 2003
    1,335
    Quote Originally Posted by DJ-Studd
    -- DJ
    What??
    Apr 2003
    Victoria, Australia
    546
    Quote Originally Posted by Luca
    What??
    Sucks about his cracked block...
    Wheel spinning goodness = Power-a-plenty
    -- DJ
    Nov 2002
    2,664
    Buy a 90 kw motor, and don't forget the Motronic ecu and crap that hangs off it. That motor comes from cars with power steering, so you won't need any of that crap.
    Mar 2003
    1,335
    Such a contradiction!
