407 V6 won't start after accessory belt change
Results 1 to 14 of 14
  • 1 Post By dimistyle
Thread: 407 V6 won't start after accessory belt change
    Oct 2015
    auckland
    14
    Default 407 V6 won't start after accessory belt change
    Driving last week, I felt some roughness and lack of power and assumed a coil had failed. Have had this before. 10 minutes of driving later I lost power steering and car stalled and died.
    I found the accessory belt to be shredded and pieces of it everywhere so ordered a belt, coil, and 3 new plugs for the rear bank.
    Not having a windows laptop handy I couldn't use my diagbox kit so I tested all the coils using multimeter and found them all to be the same, 1.1 ohms resistance across the top terminals so not sure what happened there.
    I fitted the belt, 3 new plugs and all coils again and now the engine cranks but no start, tried boosting it as battery reads only 12.3 volts but no success.
    I've pulled one timing belt cover off and pulled a few threads out, but apart from being a bit oily under there it looks tight.
    I'm wondering if the timing has been mucked up somehow. I have spark and gas pumping also..
    I'm really at a loss for ideas, looked around for how to check the timing but not sure if I have the skills to do it..
    Does anyone have any clues??
    Martin
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,329
    Yeah check timing. Often when an alternator belt shreds, it throws bits of itself into the timing belt. And puts the timing out. How does is sound when you crank it? Does it sound like it would without spark plugs (no compression)? If your lucky you may be able to retime it. But I'd be suspecting bent valves. If that's the case probably cheaper to fit a second hand motor.
    Good luck!
    2017 Renault Koleos auto
    Oct 2015
    auckland
    14
    Yeah sounds like no comp. Just trying to set up diagbox on laptop and having a bitch of a time, but it may help..
    Oct 2015
    auckland
    14
    Update, I cleared all the codes and re-scanned it. Now all clear and no codes but car still won't start.. Can diagbox find timing issues?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,133
    The only thing I can think of that is easy to check is the TDC sensor, although that should bring up a code, could just need cleaning.
    If you suspect that the cam timing is out you could remove the auxiliary belt, crankshaft pulley and pull the plastic covers off the right side of the motor and check that the 4 cams line up.
    You will need five 8mm bolts to put in the crankshaft and 4 cams. Put the engine on TDC and try to insert bolts in the holes.
    Another method if you suspect bent valves is to do a compression test, this will soon show up any irregularities in the cylinders.
    This is just my worth, but I would try the simple things first and go with the TDC sensor.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2015
    auckland
    14
    Thanks Col, I'll try to find that TDC sensor. I looked at 'checking timing' in the manual before and was totally confused. The way you explain it makes it sound a lot simpler.
    It looks like I have to remove part of an engine mount to get to the left hand timing belt cover ?
    Martin
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,133
    Yes that is correct Martin, before you remove the engine mount you need to support the engine.
    Also reading through your initial post after I posted I see that you have spark so it may not be the TDC sensor.
    There are some videos on you tube that may help as well. You may need to google by your engine type, also keep in mind that these engines are used in other makes of cars as well.
    Regards Col
    1973 Alpine A110
    Oct 2015
    auckland
    14
    I did the compression test and zero. Mechanic said it could be cylinders washed out with gas and it may take 5 minutes of cranking to start.
    Anyway that didn't work so took it all apart and pegged the crank407 V6 won't start after accessory belt change-20161129_123821.jpg407 V6 won't start after accessory belt change-20161129_123433.jpg and this is what's happening up top.
    I'm assuming this is bad news..
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Looks like bent valves then.
    Heads off and recondition appears to be the next option!
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    Oct 2015
    auckland
    14
    Mmm . Anyone know a good source for valves, guides, etc?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,133
    Quote Originally Posted by martin74 View Post
    Anyway that didn't work so took it all apart and pegged the crankClick image for larger version.
ID:	91469Click image for larger version.
ID:	91470 and this is what's happening up top.
    Its not looking good, I think those two holes are suppose to line up.
    Like Roland says I think you have bent valves.
    You will need new valves and a cam belt kit. The cam belt kits are about $430. Not sure what the valves cost but there is 24 of them.
    Did you do a compression test on all cylinders?
    Regards Col
    1973 Alpine A110
    Oct 2015
    auckland
    14
    I haven't compression checked the rear cylinders yet, will try later. Just running around trying to find a new vehicle, and looking at options ..
    Also yesterday I noticed one of the camshaft pulleys was slightly wobbly when I was cranking it, maybe 1 mm of lateral movement. I couldn't budge it by hand though.
    Aug 2016
    Sunshine Coast, QLD
    920
    We don't have the "don't like" button either. Sorry Martin I hate bent valves. ....X 24
    Sent from my GT-I9195T using aussiefrogs mobile app
    David M likes this.
    Oct 2015
    auckland
    14
    Well I never would have thought an accessory belt could wreak so much havoc. Lesson learned. No compression on any cylinder. While in there I noticed quite a few other things that make it uneconomical to save, and engines are pretty scarce and expensive here. So off to the wreckers she goes soon for $1000 minus towing, which I thought was not bad.. I was ready to part it out myself.. A Mondeo 2l manual wagon to drive around in now! ( quite practical actually)
    I would go another 407 in future but would much prefer a 2.2 manual.
