80k 306GTi-6 Service.
Results 1 to 8 of 8
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Default 80k 306GTi-6 Service.
    What exactly should this cost ? Assuming only the usual items have to be done, cam belt etc
    - XTC206 -
    Now this is a .sig
    12,269
    Quote Originally Posted by XTC206
    - XTC206 -
    normal service charges plus around $370 for the belt change if at a dealer
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    May 2001
    Sydney, NSW, Australia
    3,635
    According to Peugeot, the 80 000km service is a "C" service - a "major major" service if you like.
    The belt is quoted at $450 incl fitting, and the "C" Service $575
    That makes $1025
    Paul Vasallo told me to expect around $1000 for mine when he does it for me... mine's up to around 70 000km now.
    Derek.
    XTC
    XTC is offline
    Mar 2003
    8,566
    Ta ....
    - XTC206 -
    Now this is a .sig
    Fellow Frogger! MadBiker's Avatar
    Nov 2003
    Griffith
    194
    a grand for a service, bugger me!!!! are they rebuilding the engine for that price!!!
    1991 Peugeot 405 Mi16
    1994 Toyota Camry CSI
    2002 Honda CBR600F4i
    1989 Honda CD250U
    www.mad-biker.com
    12,269
    That makes $1025
    Derek.
    that $450 would be including the serpentine belt as well i'd say as they tend to replace that at the same time
    1 x 2018 3008
    Fellow Frogger! Dr. 306's Avatar
    Sep 2003
    315
    Its alot of work to replace the cambelt. They also replace the water pump at this time.
    '99 306 XSi Black Metallic
    12,269
    Quote Originally Posted by Dr. 306
    the water pump should only be replaced IF it is weeping/leaking or seems sus, other than that they will last till the next belt change
    takes a lot more than 80k for a water pump to wear out especially if the coolant is kept clean and changed when needed and is the correct fluid for the car
    when i sold my old Mi-16 with just over 200k on it, it still had the original water pump and wasn't loosing any coolant
    i still run the original water pump in the GTi-6 after it's first belt change
    do not be conned into changing a water pump unless it needs it
    you may need an idler though as these only have pre-packed bearings in them but then most dealers don't even keep these in stock so they even last pretty well
    1 x 2018 3008
