Weird Brake problem 307 cc
Results 1 to 9 of 9
  • 1 Post By gromzx
Thread: Weird Brake problem 307 cc
    Nov 2015
    10
    Default Weird Brake problem 307 cc
    Hi All,
    I had a strange thing happen in my auto 307 cc. My wife was in the car with it parked on a slight incline with the engine running for about 50 minutes, when she went to drive off the brake pedal was really hard and the brakes were locked on. Could barely move the car due to the brakes being on.
    Had to leave the car overnight and the next day the car was fine and has been since.
    Has this sort of thing ever happened to anyone else?
    Tim
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,145
    Sounds like the brakes where hydraulically locked on for some reason.
    Maybe something went amiss in the master cylinder.
    Don't suppose you can replicate the situation?
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    Sounds like a faulty valve in the brake booster. Once the vacuum bled out over night it released.
    Roland likes this.
    158
    I worked with a person that had a C2 Citroen that would do similar things and it took ages to find . Turned out to be a multipin connector behind the brake booster that would apply full brakes if the circuit was broken . once this was secured to not come loose by a cable tie around both parts of the plug it never happened again . His would apply full brakes randomly when he was driving as well !! Good luck
    Nov 2015
    10
    I will have a look around the booster on the weekend and see what I can find. I plugged lexia into it and did not get any faults for it
    Sent from my SM-G900I using Tapatalk
    Fellow Frogger! Roland's Avatar
    Perth
    727
    Quote Originally Posted by timbo-73 View Post
    Hi All,
    Tim
    Sorry to ask but what was it doing, "parked on a slight incline with the engine running for about 50 minutes"?
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    Nov 2015
    10
    My wife sitting in the car talking to her friend when she was dropping her off.. apparently it felt like they were only talking for a couple of minutes.....
    Sep 2003
    North Parramatta
    3,997
    So is it safe to assume it was in Park or Neutral, with the handbrake on the whole time?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Nov 2015
    10
    It was in park with the handbrake on. Really strange fault...
