2006 Peugeot 307 H/B Breakdown, leaving us stranded!
Results 1 to 11 of 11
  • 1 Post By Stuey
Thread: 2006 Peugeot 307 H/B Breakdown, leaving us stranded!
    Oct 2005
    Panorama Heights, Devonport, Tasmania
    115
    Default 2006 Peugeot 307 H/B Breakdown, leaving us stranded!
    A few days ago, we set out on a journey on the Bass Highway,only 15 kms from home, when "disaster ' struck. All of a sudden, there was a "ding", the Engine warning icon came on and the car began to run roughly, then stopped. We ended up calling the RACT and were towed home. Because I consdiered the car was under warranty, I returned it to the place where we had bought it.9 They just don't want to know about it!!) The Timing Belt was checked and the Timing and all was in order. The crank case sensor was replaced and the car started, but is missing and they can't locate the problem. Has anyone experienced a similar problem or can throw any light on what has happened and what needs to be done. Any comments will be appreciated. Thanks!
    6,495
    I think it could be the ignition coil pack, which is on top of the spark plugs. Commonly one fails, but you need to replace the whole unit as they're stuck together. A Peugeot mechanic could diagnose this through the onboard diagnostics which would log a fault code.
    2003 PEUGEOT 206 GTi
    Oct 2005
    115
    Thank you Stuey! Yourresponse was quick and helpful to pass on to the mechanic. Regards, Peter
    6,495
    No worries. It does seem unusual the crank angle sensor failed as well, though. The CAS would usually cause the car to stop and not start, where the coil pack typically just causes a misfire, but they are unrelated in terms of failure as far as I'm aware.
    Fellow Frogger! Roland's Avatar
    Perth
    727
    If it is a diesel then I would suspect a broken rocker!
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
    Oct 2005
    115
    It is a 1.6 Ltr Petrol Automatic.
    Oct 2014
    Brisbane/Australia
    387
    Start with a scan with Lexia or at a min a generic OBD2 scanner.
    Oct 2002
    Melbourne Victoria
    11,992
    Does your RACT have a Mechanical check up/diagnostic service ? If they check it over and find mechanical faults, you have a far better chance of getting things fixed under any warranty, especially if it has to be resolved later in some consumer dispute area.
    Might be worth checking.
    Ken
    Oct 2005
    115
    When I searched for an OBD2 Scanner, I came up with so many, I am a bit bewildered. Is it safer to go for one from the UK or USA, aslthough more expensive, in terms of reliability or are the ones from HK and China just as good?
    Oct 2005
    115
    The fault was the Ignition Coil Pack and with a replacement is going fine. Thanks Stuey you were right ! Appreciate your help !
    6,495
    No worries Peter. Good to see. They are a pain, being so expensive.
    PeterR likes this.
