Intake air flange gasket 407 2.2 petrol
Results 1 to 2 of 2
    Apr 2016
    34
    Default Intake air flange gasket 407 2.2 petrol
    hi, after two months with this car parked with p1160 p1161(runs rich and says air to fuel ratio failed to detect and a leak detected! Then throttle shuts and car runs rich with low air intake mode)i am certain that the old intake gasket that break to pieces upon removal was thicker than the hand cut one i made cheapily. Can anyone guide me to the best specs to get an alternative right gasket?
    my car runs out of rego in 2 weeks i'm desperate and think of selling it.
    By the way, i notice that if i over rev car after ignition instantly , car revs powerfully and smoothly ( good engine!) and it keeps like that unless i remove my feet off the throttle. Then its set to the rich- throttle closed mode.
    Thanks for any help.
    Sent from my Redmi 3 using aussiefrogs mobile app
    Apr 2016
    34
    Problem solved . Did a proper flange air gasket with plenty of thickness and used a gasket sealant.
    Car runs silent. And even check engine light gone because i removed all pcv leaks.
