BA10/5 Into a 505 wagon
    Hobart
    1,496
    Default BA10/5 Into a 505 wagon
    Hi All,
    I am looking to fit a BA10/5 into my 505 SR wagon as the 4 speed is driving me a little crazy at highway speeds. I know a BA7/5 will fit in but will a BA10 ? and if so whats involved.
    The reason I ask for a 10/5 is that I can get one fairly easily but not a 7/5!
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    12,266
    Quote Originally Posted by Pug_405_Mi16
    Hi All,
    Ben
    Ben
    as far as i know the reason the 10 won't fit in the wagon is something to do with the rear engine mount
    really though a 10 is a waste on a 4 pot as the 4 pot spins so nicely you want a smooth nicefeeling box to go with it and 10's are not that wher eas the 7's are
    10's are designed for the V6 and the 7's are the 4 pot box's
    they go hand in hand in my opinion
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    9,223
    It can be done... but not easily...
    Pitch the original gearbox mount and make up a new one styled after the mount used for the 4-speed automatic wagon installation. This mount won't fit, but could probably be modified to do so, though I would say it would be fairly easy to design one similar to do the job right.
    Then you need (probably...) to machine out the counterbore in the rear housing to locate the torque tube mounting swivel thing in the back of the box. It has a slightly larger spigot than the 'link tube' of the sedans.
    And there will be some amendments required to the finished shape of your tunnel to clear the linkages etc...
    Hobart
    1,496
    Ok Thanks,
    So I should really look for a 7/5....anyone got a cheap one going ?
    Thanks for the info Ray and Sean!
    Ben
    1973 Peugeot 504 GL
