Hi all, can someone please confirm the part number for Aus delivered, RHD, 1989, 405, MI16 with standard BE1 clutch cable?
I bought one from the UK - Motorquip VCC325 (new old stock - no longer made) but when I took it to Alipine Affair, they reckon I had the wrong one? This unit looked identical to what was in the car with the slide clip in the clutch arm and the push-in pin on the clutch pedal into the plastic clip thing.
I've seen on ServiceBox there are two type of clutch cable listed - ball on pivot (something like that) and axel control (or similar) - can someone explain the difference and hence what I probably need??
Thanks, Geoff
