205/306 stub axles & bearings
Results 1 to 17 of 17
    1000+ Posts pug-life's Avatar
    Geelong
    1,226
    Default 205/306 stub axles & bearings
    Bought and received new stub axles, bearings and seals for a rear beam rebuild.
    eBay sight in UK. Cheapest I'd seen in a long time.
    $170 delivered. Look and feel like descent quality.
    No real differences side by side of OEM stub axles.
    9,258
    What site?
    Geelong
    1,226
    What site?
    Jun 2016
    Gold Coast
    105
    Quote Originally Posted by pug-life View Post
    Thanks for the tip
    Have just purchased a pair and the price is now $140 delivered. Not sure how many left now...
    Sent from my iPad using Tapatalk
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,052
    Exchange rate is definitely helping! considering it was <0.50 six months ago
    1,730
    Yep, 121 pounds for his last two to me!
    307 HDi wagon
    407 HDi wagon
    Geelong
    1,226
    Quote Originally Posted by Matthew View Post
    For the pair? Or two pair?
    1,730
    One pair ie two.
    307 HDi wagon
    407 HDi wagon
    1,730
    Arrived!
    307 HDi wagon
    407 HDi wagon
    Jun 2016
    Gold Coast
    105
    Must be axle delivery day at DHL. Mine have just arrived too...
    1,730
    Now to have them fitted! Need a good strong press I am told.
    307 HDi wagon
    407 HDi wagon
    Jan 2011
    Traralgon
    648
    My experience is also that you may also need to finish machine the insert end of the tube to correct the interference fit on the trailing arm. Mine were 0.13mm different side to side.
    I think best approach is to press the old ones out (took about 20T) and then freeze the new ones in once you've got the tolerances right.
    Cheers.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    7,482
    I have a 12T press and sometimes the old shafts won't budge. So whilst the press in loaded up, I warm the arms up with the oxy torch. That gets things moving. I've never had any trouble fitting new shafts. Always at room temp.
    1,376
    I bought a set of these for the 306 but I might just put them in the 205.
    Sent from my GT-I9305T using aussiefrogs mobile app
    1,730
    as long as the arb fits!
    307 HDi wagon
    407 HDi wagon
    Jan 2011
    Traralgon
    648
    Matthew, not sure what the specs for your axle shafts are, but the ones I bought were a much larger inner bore so that the big ARB I bought would fit through. The originals were a pretty neat fit over the spline, the new ARB was quite a bit larger diameter than the splines. It is awesome now, put the jack under the front jacking pad and both wheels come off the ground together with the rear wheel dropping less than 15mm between loaded and floating.
    racing 405
    1,730
    Good question, given the ARB is coming out for new rubber seals I will check. Sounds like trouble ahead for me too then? I have a bar froma Xsara VTS, 23 mm for another car.
    307 HDi wagon
    407 HDi wagon
