If you have an early 205GTI, you probably have the same clutch mechanism setup as I do, with the little lever pushing against the clutch fork lever via a small steel rod (about 5cm long).
This rod is not attached in any way at either end, but the constant pressure on it doesn't allow it to fall out. Plus, at both ends it sits in concave surfaces so these would need to pull apart a fair bit to allow the rod to fall out. It does fall out when you disconnect the clutch cable if you're not careful, though.
Now, looking at the lever, it seems there was a little bellow that kept the grease in there, but mine seems to have gone awol.
The question is, does anyone have any experience/idea if there is a similar bellow available anywhere? I guess it could be one of those generic bellows you can buy for balljoints, which is kept in place with a springy ring/circlip around the base, but it would have to be a small one.
Anyone?
