bleeding the clutch on a 504 how??
Results 1 to 19 of 19
Like Tree10Likes
  • 1 Post By robmac
  • 2 Post By Pug72
  • 1 Post By Rally
  • 1 Post By Wildebeest
  • 1 Post By gordini17
  • 1 Post By robmac
  • 2 Post By robmac
  • 1 Post By Demannu
Thread: bleeding the clutch on a 504 how??
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Default bleeding the clutch on a 504 how??
    Hi
    Well the diff seal was replaced, brake lines re installed and bled.
    It turns out after doing the brakes, the clutch isnt working as its hydraulic line must also be bled.
    Haynes recommends having a specialist do it, altho it does give amethod..
    Has anyone experience/knowledge on how to do this??
    Advice appreciated.
    CCC
    Fellow Frogger! John505's Avatar
    Apr 2005
    Morwell, Victoria, Australia.
    185
    You connect a line from the left brake caliper to the choke slave cylinder and then pump the brakes and force the clutch air bubbles back up the choke plastic line. That is from memory a number of years ago. The difficulties I had were getting a seal with the line which tended to leak! Maybe others could help you with other ways of achieving the same result.
    John505
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    Hi John
    Where is the choke slave cylinder> is there a nipple to apply the plastic line to> how long does the plastic pipe need to be?
    thx ccc
    1000+ Posts Beano's Avatar
    3,142
    Correct, more or less. You simply cannot bleed them like you would expect. You can try to do it the way you'd expect and you'll be there for hours.
    Put a half-metre plastic hose between brake bleeder nipple and CLUTCH (not choke ! ) slave nipple. Pump brake. Hose may pop off, unless held on with a wire tie.
    (Before you do this, just briefly bleed that wheel's brake cylinder to get fresh brake fluid into it. Dirty fluid will come out for about 3 or 4 pumps).
    Easier is to arrange the line between clutch master and slave so there are no roller coaster ups and downs in it. That way air can travel up easily.
    Tap line repeatedly with spanner and air bubbles will go up. Pump clutch pedal a few times and repeat. Leave a few mins (or perhaps 20) if it hasn't worked and repeat. The air bubbles sometimes need time to rise.
    If your clutch hydraulics were not touched during the time the car has been off the road doing other stuff, and the clutch needs to now be bled, this indicates your seals are old and hard. They have let air in the first couple of times you put your foot on the pedal.
    You will need to re-kit the master and slave soon....ish.
    19,211
    Quote Originally Posted by ccc View Post
    Hi John
    thx ccc
    Choke is a mistake I would suggest, Clutch is intended.
    If you don't want bleed the clutch via the brakes. You can achieve the same result with a surplus fuel pump (the type with the manual priming lever). Fill a jar with brake fluid and fit a couple of tight fitting hose to the inlet and outlet of the pump.
    Put the outlet hose onto the, loosened, clutch slave bleed nipple (at the bottom of the assembly) and submerge the inlet hose into the jar of brake fluid. And pump fluid with the prime lever. When the clutch master reservoir is full the process is complete. Close the slave bleed nipple.
    The same rig allows one person bleeding of brakes, because the check valve in pump closes on the pedal up stoke and stops air getting in the system. The bled fluid ends up in jar.
    bahay likes this.
    tweed heads
    1,497
    My wife has contact lenses ,the saline solution bottles are perfect ,put some brake fluid in attach hose ,connect to open bleeder ,then squeeze
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    310
    Agree on the reverse bleeding method by pumping fluid into the slave cylinder via the nipple. I use an oil can from Supercheap with the nozzle cut off
    Toledo Oil Can - Lever Type Rigid Spout 200ml - 305257 - Supercheap Auto
    bahay and Peter Chisholm like this.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    I use a large syringe from my local chemist , only a few dollars.
    Use a short length of clear tube and connect it to the slave cylinder bleed nipple and slowly inject brake fluid into the hydrulic system as described above.
    Dano likes this.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    114
    thanks guys.
    Apr 2005
    185
    Cc,
    I meant the clutch slave cylinder bleed nipple - sorry for the confusion.
    John505
    Perth Western Australia
    2,694
    The down side to bleeding the clutch via the brake m/cyl is that the brake piston will now be entering the area where there could be a build up of crud and possibly causing a cyl leak?
    PS. I prefer the oil can/syringe method of bleeding as posted.
    Dano likes this.
    3,142
    Good point. Easy to get lead-footed on the brake pedal. Too much practice with the accelerator
    Bleeding the brake system (or its equivalent, here) needs to be done carefully, with one's foot only going down half-way, or the master cylinder seals can get damaged on lower parts of the cylinder they normally never go down to.
    bermagui
    34
    I always thought the best way was to undo circuit. Rotate slave cylinder until bleed nipple is at the top. The system will self bleed like this.
    Sent from my E5823 using aussiefrogs mobile app
    BIGRR likes this.
    Pearl Beach NSW
    547
    The syringe method has the added advantage that you can use the syringe to suck up old fluid from the master cylinder before adding new fluid the the system
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    8,932
    Here is the official manual. Peugeot use a made-up tool, a hose with a threaded union on one end.
    19,211
    I'm positive that most AFers will have a pressure bleeder in their home workshop.
    For the few that don't have a pressure bleeder system, there is the syringe, oil can and surplus fuel pump techniques. All of which have proven effectiveness in carrying out the bleeding task.
    Dano likes this.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Quote Originally Posted by gordini17 View Post
    Been wondering when someone would post this!
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    19,211
    Quote Originally Posted by BIGRR View Post
    On 404's I used to bleed the assembly off the car. All that is needed is to remove the hose support that is bolted next to the wiper motor.
    After that, the slave cylinder, with flexible nylon line still attached, will thread back through the engine bay. Best way to go after a full recondition of clutch master and slave.
    At other times all that is needed is press the "tit" in the middle of the master and the air will self bleed by gravity.
    Dano and Wildebeest like this.
    Dec 2002
    Menzies Creek
    2,541
    I also use a syringe. Takes no time at all, and is very easy to do.
    404s and early 504s had a thick, plastic tube which was difficult to bleed any other way. Later models, with the thin metal pipe are dead easy to bleed - fill master cylinder reservoir, open bleed nipple with a container underneath to catch the dripping fluid. Wait until it starts dripping... usually less than a minute. Close bleed nipple. Pump clutch pedal until it feels right. Job done.
    Dano likes this.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
