Peugeot 407 V6 Auto - Car wouldn't start
Results 1 to 16 of 16
Like Tree6Likes
  • 5 Post By codename47
  • 1 Post By robmac
Thread: Peugeot 407 V6 Auto - Car wouldn't start
    Member codename47's Avatar
    May 2016
    35
    Icon1 [SOLVED] Peugeot 407 V6 Auto - Car wouldn't start ES9A PSF1 Fuse BOX BSM Issue
    I went to shopping centre today and when I came back and cranked the car, it would only crank but won't start. I started to diagnose with the obd tool and it threw bunch of codes that says all the ignition coils and injectors aren't getting any power.
    I read on the internet that it is psf1 module needs to change.
    Do you guys know how can this be fixed? or any mechanic that you can refer ? I live in South East of Melbourne. And car is standing at the shopping centre.
    Thanks in advance,
    UPDATE: The car has been fixed. Please see my post below on how to fix the relay
    Last edited by codename47; 29th September 2016 at 10:24 AM. Reason: Updated the Solution and marked it solved
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,137
    Don't know much about the 407 but have you checked the simple stuff like the fuses.
    I found this on another forum, sounds very similar to your problem.
    Peugeot 407 not starting.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    May 2016
    35
    yup checked all fuses both inside the engine compartment and the glove box and all looks good.
    Would you know where can I source that part from ?
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,137
    Probably the best place is a wreckers or put a wanted ad on here.
    I have no idea what that part looks like.
    Regards Col
    1973 Alpine A110
    8,964
    What were the code numbers, in case it throws more light on the problem?
    May 2016
    35
    I've got the codes here:
    P0261
    P0276
    P0267
    P0273
    P026R
    P0270
    P0336
    P0261P
    P0444
    P0076
    P0082
    P033
    B2F00
    Armidale
    2,461
    Check battery voltage - I believe a dying battery could explain all your symptoms.
    Alec
    8,964
    I've gone through some of those. It looks like you have a heap of old codes that haven't been cleared.
    But the first group of P codes will stop you - all the injectors are open circuit or earthed to ground. If not a fuse, something is broken. Trace back all the way to battery.
    The crank position sensor P0335 is confused - either too many teeth or too many revs. Probably old.
    The purge canister solenoid valve P0443 is (or has been) also open circuit.
    May 2016
    35
    I tried jump starting as well but did not work. I thought may be the battery doesn't have enough power which is why it's not starting.
    So far:
    -Checked all fuses
    -Tried jump Starting the car
    -Diagnosed with OBD scanner and listed codes
    I am going to tow the car home and then replace the PSF1 myself. Anyone here can help finding the part for my car?
    2004 Peugeot 407 V6 ES9A Petrol 2.9 Litre , 6 Speed Automatic SV executive.
    May 2016
    35
    no one in melbourne has this part!!
    May 2016
    35
    Please mark it solved. I fixed the Psf1 myself.
    I will post the results tomorrow and solution. Don't go ahead and change the part without fixing it.
    Armidale
    2,461
    Fascinating - great to actually get a solution! Look forward to seeing the details.
    Alec
    May 2016
    35
    Icon7 SOLVED - Peugeot 407 ES9A V6 Not starting BSI PSF1 Fault FUSEBOX Issue
    Hi All,
    I have figured out the way to fix this issue.
    Symptoms:
    1. Car does not start
    2. Car cranks but does not fire up
    3. Electricals are all working
    4. OBD Scanner gives multiple codes such as Open circuit to Injectors, Open circuit to Coils, Open Circuit to Fuel Pump, Crank Angle Sensor error etc
    5. Fuel Pump does not prime (as per OBD as well)
    Problem:
    The relay in the fuse box under the bonnet has caused an issue. The connector that is responsible to give the go ahead for starting the car ( completes circuit for injectors/fuel pumps/ignition coils) has increased gap.
    Fix:
    1. Disconnect the battery
    2. Open the fuse box cover
    3. open the three Bus connectors ( 1 2 and 3)
    4. Take both the connectors off.
    5. Undo the Nut for earth
    6. Now slowly and carefully pull the part out by taking the clips off with the help of a screw driver
    7. Take the bottom fuse compartment attached via clip and take the part off the compartment
    8. Cut open the Relay 1 on the TOP LEFT corner carefully
    9. Do not use force to rip it apart as it can cause damage to the board.
    10. Buy a cheap relay or a FORD one as shown in photos and connect as per diagram attached.
    FUSE BOX RELAY Connectors ( C2 and same color ones are basically same connection)
    FORD Relay ( you can use any )
    Relay Break open to test (don't break others )
    Connections:
    Final Product:
    I hope that helps
    Feb 2013
    Brissy
    1
    Not sure how you worked this out, but this saved my car. Thank you!! Put some epoxy in there to hold the 'new' wiring in place.
    19,211
    A nice rational fix, without any unnecessary complication.
    Congratulations
    dimistyle likes this.
    Jan 2014
    Coffs Harbour, NSW Australia
    330
    That's very good work that could solve a few non starters - well done. Looks like there was quite a bit of heat present when the original relay chose to self destruct. Thanks codename47.
