404 Clutch Hydraulics
Results 1 to 7 of 7
  • 1 Post By Andrew Watkins
Thread: 404 Clutch Hydraulics
    Jan 2013
    Geelong
    530
    Default 404 Clutch Hydraulics
    The connection between the master & slave cylinders is via a plastic pipe.
    I need to have the master re-sleeved in stainless steel.
    When the sleeve goes in they have to re-drill the port that feeds the pipe.
    The problem is the pipe won't budge. It is well & truly stuck in the master cylinder. I used a hot air gun to the point it started to distort so I stopped.
    Any tips? The workshop said they could drill out the pipe & replace it with copper if needed.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    19,211
    Brute force and ignorance is the only way. The rubber seal over the plastic pipe has a tendency to jam up the assembly.
    You can't replace the line in copper because you need to have a flexible connection to engine.
    However, a front brake hose screws into the slave (imperial thread) and seals with a copper washer.
    At the other end at the master it's metric not imperial, however you can obtain banjo adaptor and bolt from brakequip to a imperial flare. And couple the hose end to the master. With an imperial 1/4 flare bundy line.
    I would salvage the pvc line if possible, it's a lot easier.
    Edit: The nylon line needs new seal kits. Which consist of a rubber sleeve over the nylon line and a precision washer that goes between the securing nut and seal. And the nylon line needs inserts in both ends.
    The nuts only need to be snug. If the nut is bottoming something is wrong. And you will have repeat of your disassembly issues.
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I
    Or you can use the slave cylinder and flexible hose from a late 504 or a 505 and run the copper line from that to the master cylinder.
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Jan 2012
    Gold Coast
    189
    Hi Geodon
    I replaced both master and slave with my sedan had the flywheel machined and a new clutch kit as the old clutch shuddered.
    When I put it all back together the clutch did not have enough throw to release fully so I used an old 404 trick in putting a ball bearing between the master cylinder and the actuator rod to take up slack in the system this did not fix the problem [my ute has an extension already welded to the actuator arm.]
    After lots of advise I had to pull the gearbox out remove the ball post the throw out arm pivots off replace the ball post and fit 2 thin washers between it and the bell housing it is also advisable to replace the throw out arm as they have been known to give way over time ,after this the slack was taken out of the system and machined flywheel allowed for and every thing worked perfectly.
    Lesson learnt the long way.
    Perth Western Australia
    2,694
    Geodon,
    One from the past.
    Clamp the plastic hose in a vice [wooden jaws] up close to the cylinder. Tap the cylinder with a soft head hammer pulling at the same time to release the hose.
    The copper pipe and flex hose sounds like a good mod too.
    19,211
    Geodon,
    One from the past.
    A lazy (and wealthy) person may choose to have the entire plastic line assembly made up in braided hose.
    Mar 2013
    olinda victoria australia
    723
    Most of us meet only one of those criteria
    Guilty as charged
    Andrew
    Wildebeest likes this.
