405 mirror replacement and door lock button
Results 1 to 2 of 2
    Mar 2005
    launceston, australia
    34
    Default 405 mirror replacement and door lock button
    Is there a best way or an only way to change the drivers door exterior mirror and how do you install a new door lock button so it stays on?
    Thanks in advance...........Wayne
    1000+ Posts cav91's Avatar
    Romsey, VIC
    2,329
    Quote Originally Posted by TAS504 View Post
    Mirror you need to remove the door trims to access the plugs. There's 3 screws holding the mirror to the door all are behind the triangle piece behind the mirror.
    The door snib buttons I find the easiest way is to stand outside the car with the window down and door locked. Open the snib so the locking tab inside is down. Then push it onto
    the rod. Push all the way down and it should lock on in the right position. Don't try it with the door unlocked because it'll go down to far and you'll damage the plastic getting it back off. Good luck there fun.
    2017 Renault Koleos auto
