306 into 205 does go...
Results 1 to 10 of 10
    Jun 2016
    Gold Coast
    105
    Default 306 into 205 does go...
    Hi guys have the chance of a cheap 306 2lt. Aside from the rear beam , what will fit on my 205 GTI? I'll be going Mi16 with it as already have a complete 405 donor.
    Will the 306 braking system fit the 205 and is it an upgrade?
    I've seemed to have slightly warped the front discs on mine even tho they were skimmed a couple of thousand kays ago.
    Thanks in advance
    Martin
    1000+ Posts Isis's Avatar
    1,100
    I am not sure on the condition of your 205 but recognise that if it is an original and complete car, it may end up much more valuable staying that way.
    S3 205 GTI x 4 and getting lower
    1998 S1 Lotus Elise
    2013 Fiesta ST
    2014 Audi SQ5
    1,733
    306 (266mm) disc and calipers will fit latest S3 hubs otherwise no.
    307 HDi wagon
    407 HDi wagon
    9,008
    Quote Originally Posted by Matthew View Post
    Or Si hubs.
    ACHTUNG ALLES LOOKENPEEPERS
    Jun 2016
    Gold Coast
    105
    To be honest, if I wanted return on investment I'd not have bought a 205! It is pretty original and in great nick but I'm not looking to retire on it, so I'll make it as much fun to drive while I own it. It's a phase 1 so it doesn't look like the brakes will fit then? If it's just the axle that will fit (abet with modification), then maybe the 306 isn't cheap enough. My beam has no signs to play (yet!) so was really just looking for a beam I could reno in my own time to have as a spare. If there are no other crossover parts then I'll maybe keep the peugeot stable to two cars...
    Thanks for the input fellas
    Sent from my iPad using Tapatalk
    1,733
    Martin, as is being discussed the beam is something you could do in a weekend, its not that hard. The longer it goes the more risky it becomes. I found one side of mine the bearings started to rust and ruined that side, the other side is the same as the day they put it together.
    Get the bits,ask for advice and make a puller and it a real easy thing to do, the Poms have it tough with salt on the roads that corrodes everything. We have it easy.
    307 HDi wagon
    407 HDi wagon
    7,483
    Engine
    Gearbox
    Front brakes (with Si hubs & standard shafts)
    Front hubs & shocks (if you re-bore to correct the camber)
    Inner & outer cv joints
    Rear brakes & hubs
    Master cylinder & booster
    Notice I didn't say trailing arms. You get a much better result swapping the hubs/brakes over to your GTi arms.
    Jun 2016
    Gold Coast
    105
    Excellent info. Am now tempted to fill the front yard up with another French "classic"!
    So the gearbox I'm presuming is going to be a BE3. When I change the engine over to the Mi16, which gearbox is going to be better, the one from the 405 or the 306? My 205 (BE1) has a slight crunch into second so that won't be going in.
    1,733
    Be prepared for electrical changes going from L jetronic (discrete parts) to integrated Motronic closed loop, not for the faint hearted if you don't like electrical work..
    307 HDi wagon
    407 HDi wagon
    7,483
    Good question about the gearbox. The ratios are nice and close in the 306 but it has a long cwp. It's also a bit newer. XSi ratios with the Mi16 4.43:1 cwp would be my pick. You definitely need a 1.9L Mi16 clutch.
    I'd definitely consider using the 306 front hubs (with alignment correction). That way you can use any brakes, late model CV joints etc.
