Brake line 504
Thread: Brake line 504
    May 2015
    Bribsane
    9
    Default Brake line 504
    Hey, I've been having some problems with screwing in the brake line on my 1973 Peugeot 504 and was wondering if there was a trick to it? Or maybe it's a known issue that the thread on these bolts are hard to locate onto the caliper?
    Avisford NSW
    550
    It is a matter of care and patience particularly if you have bent the pipe. only use finger pressure until you are sure you have got the thread started or you will strip the threads and be in deep sh..t. I assume you are playing with a rear caliper. If so it is easier if the caliper is not bolted on so you can adjust the angles of the pipe and caliper. There is also a slight possibility that the thread was already damaged previously.
    Perth Western Australia
    2,694
    Theswap,
    The thread type was changed at a certain year model. Under bonnet decal will have detail.
    1000+ Posts Beano's Avatar
    3,149
    Yes, theswap.....we need a little more information. Are you putting on a different secondhand caliper ? If so, it has to match, as Wildebeest says.
    If it's the old caliper which has been temporarily disconnected, what Ianrobbo says is good advice.
