Mystery Ignition Component - 406 D8 V6 - Help me identify please...
Results 1 to 14 of 14
    Tadpole Gruffnutz's Avatar
    Jun 2011
    17
    Default Mystery Ignition Component - 406 D8 V6 - Help me identify please...
    My 406 Coupe started to run rough between 2000 and 3000 rpm, but only when the engine was at full operating temp. Then it started to run rough all the time. Investigation of the ignition system revealed the component circled in red in the pictures below to be pretty much destroyed...
    I thought it was just an earth point but it looks more like a resistive load or sensor. Maybe manifold temperature, which would make sense...
    Mine is totally obliterated and from the pile of high temp plastic shards it seems to have been on the way out for some time. If I touch what remains to the bolt with the ignition on there is a distinct click from the ECU box area, like a relay switching, indicating that it does something active rather than being a passive earth point.
    What is it and where can I get one???
    Thanks in advance! ;-)
    Dec 2002
    Menzies Creek
    2,541
    It's just a noise-suppressing capacitor. It will run fine without it, but you might hear more noise on your stereo in low-signal areas.
    The cracks in your coil pack are infinitely more likely to be the cause of your symptoms.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Jun 2011
    17
    Thanks very much!!! I guessed the coil pack was FUBARed as well but wanted to follow a process of elimination. New coil pack and plugs it is then.
    Again, thanks for your prompt help. I guess I can look for some markings and ring up a replacement suppressor cap. Still curious as to why earthing it would cause the 'relay like clicking' from the ECU region if anyone knows...
    P.S. That isn't my coil pack in the photos; mine is much worse.
    Oct 2003
    Hampton Park
    523
    I have several coil packs if you want to pick up one from a rural property near Balan
    FTGH
    0413414415
    Colin
    Sent from my F1f using aussiefrogs mobile app
    Oct 2003
    Hampton Park
    523
    I have one in Melton as well
    Jun 2011
    17
    Time poor so I bought a coil pack online but thanks for the helpful offers. Now running great when cold and starting easily but still misfiring when she's at operating temp. Any ideas?
    Dec 2002
    Menzies Creek
    2,541
    Quote Originally Posted by Gruffnutz View Post
    Did you replace the plugs at the same time?
    Scotty
    Jun 2011
    17
    Yes, plugs changed. As stated, runs great cold, misfires @ normal operationg temp. Checking other sensors but totally confused. Cheers lads.
    Jun 2011
    17
    Any other ideas? Still struggling with this...
    I've tried replacing the temperature sensor as well. No joy!
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,140
    It sounds like a one of the six coils is not firing.
    Have you put a OBD2 scanner on and seen what the codes are. This will give you a hint of where to look, takes a lot of the guess work out.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Dec 2002
    Menzies Creek
    2,541
    Was the replacement coil pack new or used? Still sounds like it is the problem.
    Scotty
    Jun 2011
    17
    It's a 1998 D8, so no OBD2 as far as I'm aware.
    The coil pack was brand new. I didn't replace the leads / distribution block for the rear cylinders because it looked OK. Could that be an issue?
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    4,140
    Not being a Peugeot person was not sure of the year, was just trying to offer a suggestion to help fix. Maybe you will need to get hold of what ever diagnostic system that Peugeot used for that era.
    You could try disconnecting each cylinder individually to see which cylinder is not firing properly, it will also tell you if it is the front or rear bank of cylinders.
    Regards Col
    1973 Alpine A110
    Northern NSW
    1,079
    Maybe the wiring in that wrapping has a fault which might be affecting one of the injectors when hot? If disconnecting plugs reveals nothing maybe disconnect injectors one by one. You can take the metal clips out for the purpose so the plugs go on and off easily.
