Mi16 Starting Issues
    Fellow Frogger! NZ_Mi16's Avatar
    Nov 2003
    Hobart
    165
    Default Mi16 Starting Issues
    ok...it seems like there are a few people out there with 405 starting problems, so i thought I would add mine to the list
    After not driving my car for 1-2 days ,it wont start (ie like the battery is flat)
    the battery has been charged, and holds the charge well
    the battery is being charged when the car is running
    even with jumper leads from my work vehicle (ford transpig), it still struggles
    I have checked out the battery terminals and leads and they look ok
    I might replace the battery as a precaution, but i get the feeling something else is going on here
    Current:
    09 Volvo XC70
    89 405 Mi16
    Past Pugs
    02' 206 GTi
    90' 405 Mi16
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Have you checked this out?
    2 Hours to cnage a starter; 2 minutes to replace a wire...your pick!!
    Failing that, it could be in the actual starter motor, possibly brushes, but this problem I have linked to gives those exact symptoms & is a common one overseas where they do a lot of stop/start driving and is very hard to detect unless you put a meter on the offending wire.
    Alan S
    Fellow Frogger! Jason20's Avatar
    Oct 2003
    Sydney, Australia
    439
    Get a can of that "Start ya' bastard" stuff & spray it on the engine.
    my dad uses it on lawnmowers.
    Christchurch, NZ
    228
    I would suspect the starter motor. The 405GR I had until recently gave the same symptoms, and it turned out the starter was knackered. The same happened to my sister's 205 (twice), my old 505 and even the 203 (and they are the best ever Peugeot).
    95 MI16
    71 404 U10 ute
    66 404 coupe
    55 203C (gently warmed) gone... sold...
    12,264
    you may even have a dead cell in the battery
    just get it checked oe check it yourself first before forking out the best part of $100 for a newy
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
