205 update - Page 2
Page 2 of 3 First 123 Last
Results 26 to 50 of 57
Like Tree36Likes
Thread: 205 update
  1. #26
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    2,939
    Fantastic
    Nice Fezza
  2. #27
    Fellow Frogger! Codman's Avatar
    Feb 2015
    Skye, Victoria
    295
    Yes I was concerned about the cage Re Roady, however it is fully legal in Vic at the very lest (and vic seems to be the strictest) due to its age, but yes will be re complied as a two seater.
    Yup, just a greenhouse, i cut a hole in one end and had a blower to keep ventilation, my workshop is old and dusty, as well as being on a gravel driveway so contamination was almost impossible to 100% prevent but it did a pretty good job, luckily 205's are nice and small!
  3. #28
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    17,152
    Quote Originally Posted by Isis View Post
    I am thinking of spraying a car in my shed and wondered how to make a container like this to control the overspray and other mess. ideas welcome.
    I have curtain rods attached to ceiling around the inside perimeter of the garage and plastic curtains will hang from them when the time comes for that reason
    MayheM likes this.
    Every day is a good day
  4. #29
    Feb 2015
    Skye, Victoria
    295
    Big arrival today!
    moeozz and DeeCee like this.
  5. #30
    Nov 2003
    Bondi
    2,939
    Engine and box?
  6. #31
    Feb 2015
    Skye, Victoria
    295
    Yup, care of Huw, Engine, box and Exhort.
    Having my Headers Ceramic coated and some heat/sound insulation to put in then installation will commence.
    michael_ozzie and CEyssens like this.
  7. #32
    Jan 2012
    Sunbury
    340
    Awesome to hear it's back home with you, and look forward to following it's rebuild.
    Sent from my iPad using Tapatalk
    Michael
    1987 Peugeot 205 GTI
    Build Thread:
    http://www.aussiefrogs.com/forum/res...ti6-build.html
  8. #33
    Feb 2015
    Skye, Victoria
    295
    Touch down
    BIGRR, SilverGTi_6 and CEyssens like this.
  9. #34
    Nov 2003
    Bondi
    2,939
    Nice work!
    Whats the spec of the shiny bits?
  10. #35
    Nov 2003
    Bondi
    2,939
    Nice work!
  11. #36
    Feb 2015
    Skye, Victoria
    295
    Well so far....
    It's running B6 Billies all round, Eibach springs in the front, I'v done all the mounts and bushes front and rear, all poly's, will look at bars soon.
    It's got 306 rear disks with I guess a little extra track thanks to PGTI6, and i'v mounted 406 Coupe 4pots up front.
    The lump is obviously a J4RS, rebuilt top and bottom, balanced rotating assembly, stage 1 regrind cams, ITB's and a Haltech PS2000. I'v got a TTV flywheel in there, gearbox is-
    The ratios are (Gti 1st-4th, Mi16 5th, Mi16 Final Drive)
    1st: 2.92
    2nd: 1.85
    3rd: 1.36
    4th: 1.07
    5th: 0.76
    FD: 4.4
    I'v also got a 3J LSD set to 40/90 30Nm
  12. #37
    Nov 2003
    Bondi
    2,939
    Awesome!
    We are running a similar engine without the throttle bodies at the moment so will be interesting to see what its goes like!
    What throttle bodies did you go with?
  13. #38
    Feb 2015
    Skye, Victoria
    295
    Spent the long weekend sorting out something I had been putting off since the start, the bloody wiring in this car was a mess, having already had one engine/management swap plus all the options there was a heap to go though.
    I removed all the stereo, central locking, rear wiper, a.c., heater system, interior lighting from the looms, the re wrapped and tucked up neatly. There was a heap of wires running from nowhere to nowhere also...
    This gave me the chance to label everything as I went with a little self adhesive label printer to make everything easier next time I need to get in there.
    I then went through and put an much as I could back on the car to assign plugs and direct the looms.
    My headers a back and look phenomenal to.
    The hoist was busy, so this week it will go back up and I'll drop the front end and engine to put everything together, I will have to plug a few holes in the firewall with the heater gone, and re route the cooling system.
    Pup wasn't much help....
  14. #39
    6,864
    Quote Originally Posted by Codman View Post
    Well so far....
    1st: 2.92
    2nd: 1.85
    3rd: 1.36
    4th: 1.07
    5th: 0.76
    FD: 4.4
    That's a massive 40% jump from 4th to 5th. I'll be keen to hear of your impressions. I personally didn't like the box I built the same.
  15. #40
    Jan 2012
    Sunbury
    340
    Just looking at the drivers side intrusion bar, it looks nearly as high as mine, and I can assure you it will be painful to get in and out of.
    Michael
    Build Thread:
  16. #41
    Nov 2003
    Bondi
    2,939
    Good to see the dog hard at it....
    Coming Long nicely, the wiring its definitely the low hanging fruit!
    Cant wait to see how she goes!
  17. #42
    Feb 2015
    Skye, Victoria
    295
    I'm not sure what to expect with a lot of this car, and things will change as i get to know it, and learn what i want out of it, a tall 5th will be nice to keep it sedate at cruising, but I guess i'll see when shes running
  18. #43
    Feb 2015
    Skye, Victoria
    295
    Yep, even working around the interior is a PITA without the seats in there!, lucky I'm not to big a dude... might just climb out the passenger side
    Quote Originally Posted by michael_ozzie View Post
  19. #44
    Oct 2003
    474
    Are you sure it's 40%?
    The driveline was chosen for a street car that will see club motorsport use. I doubt Cal will need more than the 172km/h 4th gear will give him on a 195/50R15 tyre at 7500 redline.
    BIGRR and Codman like this.
  20. #45
    7,914
    I've got the same, OK for cruising and if the event has twisty roads. The event I'm doing on the weekend is the first round of the ARC and has very fast roads so the gap will be an annoyance.
    Also, after giving the car (205) a safety upgrade, seats and belts, I longer want to drive it on the road, so it would be better with the full GTi ratios. The 309 has these, the car should be sorted and usable for the second half of the year.
    I took the stock Si on an event in NSW on the weekend, long distance touring with a few short special stages, got some top 3 times on the stages and was placed 3rd outright, all in comfort, so any part touring or navigational events are likely to be in this car!
    Codman likes this.
  21. #46
    7,914
    I also fitted intrusions bars today, run above the door pockets and below the armrest, not bad at all to get in and out.
  22. #47
    Feb 2015
    Skye, Victoria
    295
    Been at it an hour or so per night,now have my engine control mounted so ready to start terminating the loom.
    Have my elite 750, fuse box, igniter and wideband controller all mounted on the black plate in the photo now under the dash, nice and tidy with fantastic access
    Dash is so incredibly crumbly, that's about the best I could do, once it's on the road I will look doing some thing else with a digital dash, but it will do for now.
    At a point where I can actually do a list...
    Richard W, CEyssens, Isis and 1 others like this.
  23. #48
    Feb 2015
    Skye, Victoria
    295
    First signs of life are coming back!
    I have been tediously working though the wireing of the entire car, with three systems to work through its been very slow going but I'm stoked on the results.
    I've had to go through the 205 loom to strip everything out, between the old engine conversion, and everything I have removed there has been hundreds of wires I have traced, followed and disconnected, I have done so at the plugs, removing everything, not just cutting and capping as a lot was before.
    So now ever thing under the dash is as sorted and neat as I can get it, only the D/S window switches I still have to relocate, will make a plate and mount them on the right-hand side of the dash where I have to trim around the cage.
    The haltech system in basically done also, just the intake to go.
    The truly exciting moment was fitting up the seat and shifter, I had been forceing my self to wait as not to impede access, honestly still may have jumped the Gun a little but after weeks of following wires I was dieing for visible progress
    BIGRR, Richard W, CEyssens and 1 others like this.
  24. #49
    Feb 2015
    Skye, Victoria
    295
    Got my big boy shoes fitted up so I can mount the 406 brakes, might buy a large mallet on the way home.....
    CEyssens likes this.
  25. #50
    980
    Snap, exhaust just like mine! Good effort Cal.
