The dreaded carbon build up on the intake valves...
Page 1 of 4 1234 Last
Results 1 to 25 of 93
Like Tree21Likes
Thread: The dreaded carbon build up on the intake valves...
    Fellow Frogger! 207cc Sport's Avatar
    Apr 2016
    Gold Coast Hinterland
    327
    Default The dreaded carbon build up on the intake valves...
    Folks, doing editing, the whole freakin' original stuff vanished . . .
    Attached Thumbnails Attached Thumbnails The dreaded carbon build up on the intake valves...-subaruupperenginecleaner.jpg
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,373
    It's an interesting thread. A couple of days ago you were saying that frequent sparkplug changes promote a clean burn, and you use BP 98 (Ultimate). I am expecting you to say you have a super clean intake/combustion area. Yet you have a large amount of crud build up on the valves, enough to activate fault codes. OK, clean burn in the cylinder does not relate to clean intake area, but BP Ultimate claims to clean it and keep it clean. So BP Ultimate does not do what it is claimed to do? Or have you only been using it since you found the initial build-up a couple of years ago?
    Not meant to be nit-picking, just like to ascertain if BP 98 does the job we pay for. As a WRX owner, with Subaru recommending the additive at every service, I am assuming that the Subaru engine is also prone to intake crud build-up, so I guess it's an engine design thing. In the past I have found that poor valve stem seals contribute to intake valve build-up, but I think these modern engines may not run seals?
    Chris M.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    Apr 2016
    327
    Thanks...
    I attempt to keep the intake area as clean as I possibly can, but with this engine (direct fuel injection - no fuel flows/cleans over the intake valves), you will still get carbon build up from the EGR/PCV setups.
    Check this out:
    Is Carbon Buildup a Problem With Direct-Injection Engines? » AutoGuide.com News
    Subi engines, being boxers, are prone to a bit more sludge around.
    Armidale
    2,286
    That article is very vague and gives no clue as to where the carbon comes from, apart from a vague reference to "certain markets with varying factors such as fuel quality"...
    If valves are sealing, and burnt combustion gases exit via the exhaust valves, why are the intake valves affected? Is it to do with EGR? If so, isn't it caused by using wrong oil rather than wrong fuel? And wouldn't carbon build-up in the EGR valve itself (and CAT & Turbo?) be more of a problem than the back of the inlet valves?
    Alec
    shanadoo likes this.
    Apr 2016
    327
    You need to google - 'direct injection carbon build up petrol'
    Stacks of more info.
    Check out this one also:
    http://www.enginebuildermag.com/2015...rbon-deposits/
    Cheers...
    8,615
    The crud is condensed from oil vapour coming from the PCV. Direct injection means no petrol wash to clean the valves. Use full synthetic and a spray clean. I've heard recommendations for Seafoam (sometimes found) as well as Subaru. This document may be of interest - http://www.ds3spirit.com/InfoRapid/Hesitation.pdf
    Armidillo and Doush_504 like this.
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,973
    I don't come in the Peugeot Forum much but this is interesting, its like going back to the days when heads were removed for de-coking.
    addo and JohnW like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Apr 2016
    327
    It's like - 'Back to the Future'...
    Dec 2002
    2,524
    I cleaned an amazing amount of carbon from the inlet valves of an Audi A3 with direct injection petrol engine.
    The power difference after this was phenomenal.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Don't remind me!
    16,609
    I think this sort of "back-gunk" is one of the things that Terra Clean franchise setup in the UK was so effective at removing, and why they got rave reviews.
    Apr 2016
    327
    Also BMW introduced, for their dealers, a crushed walnut shell-blasting machine, with an attached vacuum hose, for the Mini Coopers.
    So do yourself a favor.
    Follow the above tips that have worked so well for me, or easier, get a mech to get that crud off your valves, if you've done 70,000 +
    Scary:
    I read an article about a dude who owned an Audi R8 - V8 direct fuel injection.
    He was fastidious, but you don't learn anything, if there aren't dudes like him. e.g. The VW 'death diesel' fiasco guys that found it by chance.
    Anyhow, (in summary) after 15,000 he dyno'ed and saw a slight decrease in power. At 25,000, the power had dropped another 5%. At the 50,000 dyno, the power was down 25% from stock!
    Reason - intake valves were covered in nasty carbon crud. Cost a few grand to clean out.
    And a $200,000 car?
    Tip: Use the SA459 with every oil change.
    Oct 2005
    vic
    845
    Provent/oil catch can will minimise but not remove deposits.
    Where does the PCV vent into the engine?
    I assume after the turbo & before the intercooler?
    In which case cleaning valves is only half the job.
    The same oily crud will be coating the inside of your intercooler.
    It's all about emissions.
    It's not about long term reliability.
    "Sorry Sir, that is not our problem as your warranty has expired....."
    Happy to be corrected about this - but it is the way of the future.
    Get a 1963 whatever, put a big hulking V8 in it and enjoy.
    8,615
    8,615
    I should also have shown the oil separator. The dreaded carbon build up on the intake valves...-deshuileur.jpg
    Apr 2016
    327
    Hi seasink, The pic of the oil separator is interesting.
    Can't seem to find it on my engine however.
    Apr 2016
    327
    I have tried oil catch cans in the past. Only gave me fault codes.
    Lesson learnt:
    You need a 19 mm hose to connect from the oil catch can. Most cheapies come with a 13 mm hose and dudes fit those on somehow, with bad results.
    My Pug mech does not like them, due to the high negative pressure in the top of the cylinder head. I use SA459 instead.
    I have seen this twin oil catch can for the Mini Cooper.
    https://www.youtube.com/watch?v=DvM4PL6SRdM
    Was going to install one, but settled for SA459 every 5,000 with oil change.
    8,615
    Here's the head: The dreaded carbon build up on the intake valves...-culasse.jpg
    And here's the cover - the bulge has the oil passages integrated The dreaded carbon build up on the intake valves...-couvre-culasse.jpg
    There's a page on built-in separators at http://www.sogefigroup.com/fr/produi...urs-huile.html (in French) with the virtues of the different types. It would appear that this engine could do with a better one.
    48
    Quote Originally Posted by 207cc Sport View Post
    Lesson learnt:
    If you were using a catch can that vents to atmosphere you would have a boost leak from the rear pcv hose, assuming it wasn't an issue with the connectors, hence the fault codes.
    Have been running a catch can on the front pcv hose for the last 25000km which does get a bit sludgy, so it's definitely helping, even if only a little. Haven't put a can on the rear yet though.
    Agree with using the upper engine cleaner at oil changes too.
    6,248
    Quote Originally Posted by 85Fuego View Post
    Well, 1963 may be going a bit far! Just get anything without DI. I'm glad I didn't plump for a 207 when I bought my 206 - which I did consider, among others. But my reasoning for the early 206 (138) was low(ish) maintenance. Phew!
    2003 PEUGEOT 206 GTi
    ccc
    ccc is offline
    Member ccc's Avatar
    Dec 2014
    brisbane
    113
    Has anyone noticed a reduction in build up after long time use of 98 octane?
    Apr 2016
    327
    Quote Originally Posted by ccc View Post
    I have used 98 octane since owning the Tart. No doubt it would have helped for a cleaner burn, cleaner injectors and a cooler running engine (a bit), but will do naught to reduce the intake valve carbon buildup on a DI engine. My valves were coked after 70,000.
    FUN206 likes this.
    The French Tart… 207cc Sport THP150 and now a RCZ Mk2 THP200
    Apr 2016
    327
    Stuey, no doubt you may well own a DI engine in the future, unless you wait for an all electric… Scalextric maybe?
    Direct Injection is mostly all they are doing… refer to story earlier about the Audi R8 owner.
    More data:
    5 Q&A's: Intake Valve Carbon Build-up, Direct Injection & Mini Coopers
    BMW Engine Carbon Cleaning | Direct Injection Engine Carbon Build Up
    and
    https://www.youtube.com/watch?v=ZIO1...8lF0f65ldg0lPB
    I had smoke coming out of the zorst for the first two times, but now hardly any at all.
    Looks like I may have won this battle...
    Even my Pug dealership sells SA459 and use it in the workshop.
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    623
    The thing is
    fuel doesn't get to clean the valves as it is injected directly in the combustion chamber
    Have a look at this
    1.6 THP Intake valves with combustion residues buildup - eTuners
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    6,248
    Hey, Simon Townsend, give some of us credit for knowing the state of current engine development.
    Jul 2014
    brisbane, Australia
    15
    direct injection motors suffer from carbon buildup because of the emissions crap that forces oil vapours from PCV (crankcase pressure) into the intake manifold and it sticks to the hot metal on the head and intake valves.
    the gunk isn't coming through the air filter its coming from the engine itself. stupid regulations due to emission standards cause the bulk of carbon problems in modern cars.
    after you clean it , reroute the pvc hose to a oil catch can and run that back into the intake. you shouldn't have the problem anymore.
    infact, later models of the 308, 208 and rcz came fitted with pvc valve caps to block it off, on both the back of the cam cover and the intake.
    FUN206 likes this.
