205 wipers problem: advice sought
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By EvilElmo
  • 1 Post By PeterT
Thread: 205 wipers problem: advice sought
    Fellow Frogger! lozenge's Avatar
    Castlemaine
    493
    Default 205 wipers problem: advice sought
    suddenly the wipers won't do intermittent, nor will they park themselves.
    does this indicate imminent demise? or something else?
    any wisdom appreciated, regards, Lo.
    Fellow Frogger! EvilElmo's Avatar
    Jan 2016
    nsw
    612
    Try cleaning the contacts in the switch on the stalk.
    Castlemaine
    493
    thanks Elmo.
    9,008
    Parking is controlled locally. I would suspect the wiring in and around the motor. Generally speaking however, wiring in these cars is never far from taking a break for whatever reason at any time, just because.
    ACHTUNG ALLES LOOKENPEEPERS
    Castlemaine
    493
    thanks Schlitz. yep, you're right, "just because"...
    that's why we love dem wilful little critters.
    1000+ Posts michaelr's Avatar
    1,393
    Self parking is controlled in older cars (and possibly new cars too) by a set of contacts within the wiper motor gear housing which maintain the power supply to the motor until in the park position.
    First check that there is a constant 12 volt supply arriving at the wiper motor (with ignition on) as this is needed for the self park. If this is OK you should be able to open the unit to reveal the parking contacts which may simply require a clean.
    The intermittent function provides a pulse to the wiper motor to start the wipe, the motion being completed by the parking contacts.,
    Michael
    Member, Citroen Car Club NSW
    Jan 2016
    nsw
    612
    Quote Originally Posted by lozenge View Post
    thanks Elmo.
    Thank me if it works!
    lozenge likes this.
    Castlemaine
    493
    Quote Originally Posted by michaelr View Post
    much thanks, Michael, that's helpful info.
    7,483
    You might find this useful. I threw away all the standard wiring for a simplified version in the race car. Park is wire #62.
    Attached Thumbnails Attached Thumbnails 205 wipers problem: advice sought-wiper-motor-connections.jpg
    EvilElmo likes this.
    Castlemaine
    493
    thanks Peter for taking the trouble to post that.
    Castlemaine
    493
    SO.. after much frigging around I took the car to my trusty mechanic.
    after much frigging round on his part, cleaning contacts and switches and
    head-scratching and doing every possible thing he could think of,
    he gave the car back to me, problem unsolved.
    the next morning Susan reminded me that I'd recently replaced the flasher can,
    complaining when I did that I'd been sent one with four pins rather than six
    (the indicators worked fine with the 4 pin relay nevertheless) "maybe that had
    something to do with it.." mmm, true, it hadn't rained in the weeks between replacing
    the relay and discovering the wipers weren't parking or intermittering..
    so I fished out the old 6 pin flasher can which had been playing up and stuck it in.
    sure enough, the wipers now worked just as they should!
    thus none the wiser about this, just part of the wilful charm of a 205, or something
    amiss amid the electrics, particularly the glovebox fuse tray. thanks again, Lo.
