203/403 interior plastic revival
Like Tree2Likes
  • 1 Post By Commerciale
  • 1 Post By EvilElmo
Thread: 203/403 interior plastic revival
    Nov 2015
    New Zealand
    23
    Default 203/403 interior plastic revival
    Just wondering if anyone has any tips for getting a gloss back on interior plastic bits on 203/403 that are dulled/oxidised/not cracked but surface is rough.I was thinking of trying brasso?
    1000+ Posts Beano's Avatar
    3,149
    For large sections of black interior, I used to buy a vinyl colour change spray can...
    It smells pretty toxic, so I would recommend not being as casual as if you're using a spray can of paint.
    Can't vouch for the colour being the same if you use another colour apart from black. It looks like new afterwards though.
    But try "Armour All" first....it's a type of wax.
    Fellow Frogger! Commerciale's Avatar
    Dec 2010
    181
    Welcome to the world of French casine plastic. Being based on milk you will notice its enduring smell. The main source of decay in this material is sunlight. The stages range through surface flattening, discolouration from gray to brown, surface cracking then final disintegration. If you catch it at the first stages some refurbishment is possible by abrasive polishing.
    The first step is to try a mild abrasive - Brasso is good. If you make no immediate progress go coarser and work down. You may have to go down to 800 wet and dry abrasive paper but start with 1200. Addition of soap to the paper will reduce the cutting power if necessary. Follow with a coarse cutting compound (such as Kitten) and finish with Brasso. A final coat of a good automotive wax will give some degree of protection for the future. You could use ArmourAll but wax is more durable.
    Finally, don't be tempted to use a powered felt or cloth mop to polish the plastic - it will just dig into what is a fairly weak and degraded surface - ask me how I know!
    Dano likes this.
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    503
    Armour All - really?
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    Fellow Frogger! EvilElmo's Avatar
    Jan 2016
    nsw
    612
    CRC 226 and a soft cloth works well for removing oxidization. I've used it to restore plastic bumpers and such.
    Dano likes this.
