2008 407 2L Hdi Auto Engine Surging at low speed
Results 1 to 8 of 8
    Oct 2014
    Brisbane/Australia
    392
    Default 2008 407 2L Hdi Auto Engine Surging at low speed
    We are getting engine surging at low speed and low rpm in our 2008 407 2L Hdi 6 speed Auto. What causes this? It is not something I experienced in our 2007 Citroen C5 with the same engine and gearbox.
    Oct 2014
    Brisbane/Australia
    392
    Anyone?
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    364
    Have you had a look at this thread yet:
    407 Surging Problem
    Does it idle fine?
    8,951
    See above. I think your first task is to take the car on a low-traffic motorway, for a long steady fast run, to give the FAP system a chance to regenerate by itself. Only then start looking for faults.
    I hope the right low ash oil is in it.
    Oct 2014
    Brisbane/Australia
    392
    I have had the car about 4 weeks after having a Citroen C5 with same engine & transmission written off.
    I am using Penrite DL/1, recommended oil for the 2L Hdi engine.
    I have no idea what was used previously.
    OK, Idle is perfect. I have not done a highway run since owning it.
    Thanks guys...
    123
    Thanks guys - you have solved a 406HDi problem for me. The car has been surging on and off at low speeds and the turbo has seemed like it was not kicking in until over 3000rpm. I read the question above and followed the links and found the matching problems as mine. The suggestion seemed to be the Mass Airflow Meter just behind the air intake box. One writer had success at cleaning his, another found it made no difference but swapping the unit achieved success. I pulled mine out and liberally applied electrical contact cleaner, wiped the small metal plate with kitchen paper and a tooth brush. Car runs really well again! The successful writer talked about the metal plate having oxidation on it - it certainly seemed like something was on the plate. Peugeot have two new units available but the cost is about $270 +gst, I hope my solution lasts!
    Glenn
    Fellow Frogger! andrepug's Avatar
    Victoria
    454
    Glenn, this supports your efforts;
    https://www.youtube.com/watch?v=tT8yHXJCjJI
    123
    Yes, this is one of the things I found when I was following the leads. Thanks. Glenn
