pug 505- the manual gearbox conversion is starting!
    Feb 2013
    israel
    822
    Default pug 505- the manual gearbox conversion is starting!
    hi guys, the ba7/5 box is on its way to get installed, it's from a 92 wagon with a cable operated clutch.
    just a couple of questions for the beginning:
    1. is it necessary to replace the ball stud in the clutch housing, and if so- how do you remove it? (a new one was ordered just in case).
    2. can the rubber damper be fitted without removing the ball stud? it was missing, a new one was ordered.
    3. is it necessary to get a new release fork?
    thx
    19,211
    I'd replace the fork and the thrust race because it not something you want to do later
    And make sure the clutch is sound and flywheel smooth too for the same reason.
    If you have the funds a full clutch kit plus a fork is not a bad idea.
    I've seen a pivot ball break, but forks do regularly (they bend actually)
    Feb 2013
    israel
    822
    thrust race? what is it?
    1000+ Posts Beano's Avatar
    3,142
    Just the outer part of the ball, and slightly to one side.....where the fork presses on to it.
    I did replace a ball stud once , and if I recall correctly, I punched it out from the rear, after taking off the bell housing. I then hit in a new one with a copper-faced hammer (though once you get it started, you could use a bit of hardwood between it and the hammer)
    Absolutely and definitely replace the throwout fork. I have seen a few broken ones, and and heard about many more. They are known to last about one and a half clutches. In other words, need to be replaced every time.
