2001 306 Dash Light issues
Results 1 to 8 of 8
    May 2012
    140
    Default 2001 306 Dash Light issues
    dash lights - lamp for fuel light went out a while (1-2yrs) ago - occasionally comes on for a bit (rare) and then off, but mostly off
    now the dash lights come on for a bit on first start, flash/flicker a few times and then go off within a minute or so and then they stay off until a restart
    any ideas? sounds like a dodgy wire connection, but where?
    thank you
    ALW
    May 2012
    140
    lights worked for the last week and now gone again
    haven't pulled anything apart yet (presumably getting to plug connecters requires the instrument binnacle out) , but nobody had this before?
    Mar 2011
    413
    ALL warning lights? Say, even the foglamps and battery discharge? Indicators? Sounds like an odd problem if they suddenly work again when turning the car off then on again. Perhaps a crossed wire somewhere that's causing them to only come on during a certain startup routine.
    2000 306 GTi6 'Josie'
    May 2012
    140
    I'll have to check more carefully - drove the car the other night and no lights for any instruments (speedo, tacho, fuel etc) - can't recall if the ignition light came on on start up - don't think that headlights light either came on
    and this time it didn't light up on restart - dead as a dodo
    1000+ Posts Peter C's Avatar
    SWOTR
    3,657
    An earth? Dry joint?
    May 2012
    140
    yes, good thought, but where does one look?
    May 2012
    140
    now have the instrument binnacle out - that was fun
    looks like I have failing bulbs, I guess to be expected after 15yrs
    will replace them all tomorrow and see how we go
    May 2012
    140
    and confirmed - seems when the bulbs go they continue to arc for a bit and then die
    I've replaced all 24 but annoys me I had to buy 6 from Supercheap (due to limited supply elsewhere) and 1 out of the packet was faulty - gonna take the 6 back as they look cheap and I don't want to be pulling the binnacle out on a regular basis
    although, I am quick at it now - at least once I used YouTube to show me how to unclip the rear electrical plugs
