206 GTI Lower Control Arm Ball Joint
    Dec 2015
    Central Coast, NSW
    38
    Default 206 GTI Lower Control Arm Ball Joint
    Hey Guys,
    Seems i busted the control arm ball joints in the stack i had, 3-5mm play in them, i've done abit of searching but can only find full control arms, can these ball joints be replaced at all?
    Cheers Josh
    Gone Fishin'
    Aug 2015
    Nagambie
    1,937
    I would think only if bolted to the arm.
    The modern trend is all-in-one these days for cheaper assembly.
    Dec 2015
    Central Coast, NSW
    38
    Bugger! Thanks.
    1000+ Posts lion5's Avatar
    Jan 2013
    1,675
    yep, it just comes as one piece. So if the ball joint is knackered, you replace the whole arm.
    I got an arm for real cheap from the UK. Sure, they sent me the wrong one, and i ended up gettnig the right one a month or so later, but it was cheap and I wasn't in a hurry.
    Pour le peuple colonisé, la valeur la plus essentielle, parce que la plus concrète, c'est d'abord la terre: la terre qui doit assurer le pain et, bien sûr, la dignité.
