406 Seat Belt Wire
  • 1 Post By sfrawley
Thread: 406 Seat Belt Wire
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    Default 406 Seat Belt Wire
    I recently installed a new driver's seat in my '03 406 to replace one with a broken frame. I would like to replace the seat belt stalk with the better one from my old seat, however there is a wire leading from the buckle to the harness under the seat that does not appear to have a connector that can be disconnected. Is there a way to disconnect the wire or do I have to cut and join?
    Stephen
    '03 P406 HDI
    '16 Renault Master
    Dec 2005
    HOBART
    1,265
    It will definitely have a connection somewhere. Probably under the carpet or the Centre console. More likely the second. You will need to do a little exploring.
    Before you do, get the replacement stalk. It will give you an idea how close the connector is
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Mar 2014
    379
    It may not have a connector, I could believe that it is loomed into the multi way seat connectors. Start with the old seat and try untangling all the looms from the seat, you'll quickly see if it terminates in its own connector. Cut and join is a quick fix, the wire is just for the seat belt detection so it doesn't need to carry much current.
    406 HDi
    Feb 2001
    Goolwa SA
    339
    Found the connector, thanks. I just needed to look harder. The stalk is integral with the pre-tensioner device so there are two connectors under the seat.
    addo likes this.
    Stephen
    '03 P406 HDI
    '16 Renault Master
