Looking for 505 petrol cap
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By Hugo
Thread: Looking for 505 petrol cap
    Aug 2013
    64
    Default Looking for 505 petrol cap
    Hi everyone,
    I have recently acquired a 1992 petrol 505 which is missing the petrol cap.
    The petrol cap area looks like this:
    The inside diameter is about 41.3 mm. The cap is clearly a screw type.
    I went to Supercheap Auto, which have a good range of Tridon brand replacement caps, but Tridon doesn't list replacement caps for Peugeots.
    Any idea where I can get a replacement cap?
    I'll give EAI a call on Monday, but wanted to ask for some general advice. Is there just one petrol cap standard for 505s? Cheap options also considered.
    Thanks in advance,
    Hugo
    Attached Thumbnails Attached Thumbnails Looking for 505 petrol cap-img_20160219_161322-sml.jpg
    1000+ Posts Peter C's Avatar
    SWOTR
    3,657
    From 1986 up to at least 1988, 505s had a bayonet fitting. Don't know about pre 1986. So that's at least two types.
    Fellow Frogger! EvilElmo's Avatar
    Jan 2016
    nsw
    612
    There's a 505 at my local wreckers, dunno what year exactly...
    Dec 2005
    HOBART
    1,265
    The unleaded 505 has a different petrol cap to the leaded ones, at least in comparison with yours. From memory yours are a screw in type
    1998 Peugeot 406 D8SV Manual
    1999 Peugeot 406 D8ST Auto
    2002 Peugeot 406 D9SV Manual
    1994 Peugeot 306 XR N3 Hatch
    Over 60 Pugs in my time
    Gerry Mullock
    Don't remind me!
    16,609
    Any progress on this one? Is it possible the filler neck is not "native" to the car? Various searches in French and English have failed to bring up a male threaded cap for the 505.
    Aug 2013
    64
    Thanks for all your replies.
    I tried EAI, but they don't stock any fuel caps for the 505 any more. The guy there however confirmed that all unleaded vehicles had the same cap, presumably the screw type.
    The Tridon cap model TFNL227 that I tried at Supercheap Auto had a diameter of 45 mm, was listed to fit a Renault (R19 among others) and so I tried it, but it felt too large in diameter/wouldn't fit. Later I noticed in the Triton's PDF for fuel caps that there is also one cap with a diameter of 44 mm that I might try, although the pitch of the thread might be incompatible. Hopefully if it fits I will still be able to closed the petrol cap door.
    If the filler neck is "native" to the car or not - I don't know. Good question. I might try to contact the former owner to see if he knows. I wonder if it is a filler neck used internationally or one just used in Australia.
    Otherwise I'll try some wreckers.
    Thanks again and any more tips much appreciated. I think fuel caps are one of those variable parts, making finding a replacement harder than some other parts.
    Hugo
    Avisford NSW
    550
    Is it a station wagon? they were the only 505's sold with a true threaded cap.
    Your picture doesn't show me a true thread.
    I doubt Tridon or any other local source will have what you need but I have S1 and S2 505's that I am wrecking and have almost certainly got the one you need.
    Aug 2013
    64
    Hi ianrobbo,
    Yes, my 505 is a station wagon (I forgot to mention that above). The thread on the fuel inlet was about 3 turns of the thread, so maybe it is a true thread?
    I'll contact wreckers and let you know how I go. I'll try here in Melbourne first because I can try the part out to make sure it is correct before I buy.
    Hugo
    Dec 2005
    HOBART
    1,265
    Quote Originally Posted by Hugo View Post
    Hi ianrobbo,
    Hugo
    Ianrobbo will definitey have the correct one
    Gerry Mullock
    Avisford NSW
    550
    Hugo
    There is only one threaded cap ever fitted to 505 wagons.
    I have 1 only available and they are very hard to find .
    Yours for $40 including post.
    Aug 2013
    64
    Hi all,
    My mechanic Justin Fischer fortunately had one. In the very old looking orginal Peugeot spare parts bag! By the way, for future reference, the Peugeot part number is 1508 53.
    Ianrobbo, thanks very much for checking for the cap.
    Thanks for everyone's tips. Now I'll see how the newly acquired wagon goes.
    Hugo
    addo and okalford like this.
    Oct 2005
    Germany
    6
    Default 1508.28
    Hi Hugo,
    probably an issue that might afford changing the tankfiller also. 1508.17 would be the Australian version of he cap, 1508.28 is the Euro-version but, this is not a screwtype but a bajonett-lock. If it helps, I keep a new cap, also a used Euro-fillertube if necessary, can provide you with a pic of the Euro-version also.
    Just read the forth-running of the tread, also that it depends a wagon. If the problem is solved, fine, otherwise give me a notice
    [email protected]
    cheers
    Jürgen
    Hi everyone,
    Thanks in advance,
    Hugo
    Aug 2013
    64
    Hi Jürgen,
    Thanks for the info. The replacement cap working well now.
    Hugo
