Are 307 Hdi A/C compressors serviceasble?
    Nov 2005
    Geraldton
    1,596
    Default Are 307 Hdi A/C compressors serviceasble?
    A friend of mine has just been told that there's an internal fault in her A/C compressor and that for a mere $1800 her mechanic can fix it.*
    Hmmm, says I. We need a second opinion.
    Ex
    *Mechanic reputable but not a Pug specialist (they exist 500kms to the south and haven't proved particularly good at servicing this car.)
    In the Shed(s):
    In the Past:
    19,211
    Compressor, depending on brand, are often able to be serviced.
    The question is if it's a practical proposition to service rather than replace.
    A new compressor has decent warranty, a repaired unit won't (typically 3 months max).
    A $1800 I would surpised if a new aftermarket could not be sourced and fitted. Unless there is a lot of time R &R labor.
    The exception is a clutch fault which is a simple replacement (without opening up the compressor)repair and bloody outrageous at $1800.
    My advice is to seek a real auto air technician and not a mechanic taking guesses at the possible work involved.
    An example of compressor a at cost:
    http://speedyairspares.com.au/catalo...eot-113-1.html
    8,948
    The cars I know best have a Sanden SD7C16, and the repair manual for SD models is online. They are repairable, but it may not be economic depending on the problem. As above, find a car AC specialist.
    19,211
    FWIW Ashdown Ingram have that very compressor listed as being available.
    Fellow Frogger! Ren25's Avatar
    Dec 2002
    Perth
    299
    As Robmac has said, take it to an aircon man. There are a lot of things which can cause the aircon to not work. The p/o of one of our 406s went to great expense to buy a new compressor which was in the boot when we bought the car. It wasn't the compressor, but a relay in the BSI unit.
    Armageddon was yesterday
    Today we have a problem
    2000 406 Hdi X 3
    2003 307 Hdi
