505 SR 2.0l rear main seal - cant seem to find one
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By Bob D
  • 1 Post By Beano
  • 1 Post By dacia4x4
Thread: 505 SR 2.0l rear main seal - cant seem to find one
    Member colj00's Avatar
    May 2015
    perth
    68
    Default 505 SR 2.0l rear main seal - cant seem to find one
    hi guys, having a hard time locating a rear main seal for a 2 liter SR 505. ebay isn't helping me so i would appreciate if someone could point me in the right direction. cheers.
    edit* i just found one, apparently it fits the OHV 2 liter XNA2 engine (listed as 1971cc) im hoping Peugeot only sold 1 type of 2.0 engine for the 505.
    http://www.ebay.com.au/itm/Timken-22...rrXYFBNoiSI4kw
    Current fleet:
    Toyota Yaris 2007
    Ford Falcon EL wagon 1996
    Nissan NX 1993
    Previous:
    Peugeot 505 SR 1985
    Nissan pulsar 1998
    Nissan pulsar 2000
    Toyota Corolla 1990
    Our most Southern Member (Tas)
    277
    Only a slinger ?
    No seal I dont think.
    colj00 likes this.
    1000+ Posts Beano's Avatar
    3,142
    Correct.
    If it's a 2 litre 505 SR, they have a slinger.....no seal. And no front seal either.
    colj00 likes this.
    May 2015
    perth
    68
    righto, so what part would get replaced if it is leaking?
    cheers
    Current fleet:
    Toyota Yaris 2007
    Nissan NX 1993
    Previous:
    Peugeot 505 SR 1985
    Nissan pulsar 1998
    Nissan pulsar 2000
    Toyota Corolla 1990
    Feb 2013
    israel
    822
    If it's engine oil il it may be sump gasket or rocker cover gasket.
    If it's gearbox oil ot may be the bell housing seal.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    Quote Originally Posted by colj00 View Post
    cheers
    Pistons and liners to reduce blow by .
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    tweed heads
    1,497
    Check that the gause filter in the filler pipe isnt blocked causing back pressure in the sump ,and you have the correct dip stick ,not overfilling with oil ,try running it half full see if that makes a difference ,,give the area a good clean so you can see exactly were the leek is .pugs
    May 2015
    perth
    68
    ok thanks all.
    Current fleet:
    Toyota Yaris 2007
    Nissan NX 1993
    Previous:
    Peugeot 505 SR 1985
    Nissan pulsar 1998
    Nissan pulsar 2000
    Toyota Corolla 1990
    Apr 2014
    kilsyth (lower montrose) vic,
    214
    Hi colj00,
    As good advice from previous post,crankcase breathing (gauze filter and oilfiller pipe for restrictions),rocker cover gaskets/stud seals,excess blowby from worn piston rings,oil level over full,sump gasket,oilfeed pipe to head mount bolts and copper washers.As beano stated there is no rear main oil seal which runs on rear crank journal area,however there is a rubber seal down either side of the rear main bearing cap which seals against engine block along their length and butts up against the sump gasket at its end.I have seen these 'shrink' back a little .What I used to do was remove sump and rear main bearing cap (crankshaft end float washers sit either side of bearing cap),replace cap side seals,modify oil return grooves in bearing cap (made larger),refit rear main cap (grease or oil on new seals so slide into block without dragging/tearing) snip off new seals(about 2mm above block sump mating surface) after fitted Refit sump,fill with oil etc... I hope this helps more than confuses you,good luck. jim
    colj00 likes this.
    Oct 2011
    Toowoomba
    650
    If the engine has been rebuilt at some stage and the rear cap side seals were trimmed a little too short they will shrink, as described. This produces a persistent small leak from the bottom of the bell housing. Puts a little puddle on the driveway, but the oil consumption isn't alarming.
