Maintenance schedule
Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By addo
  • 1 Post By SLC206
Thread: Maintenance schedule
    Member warsch's Avatar
    Feb 2016
    38
    Default Maintenance schedule
    I've got a question regarding how are Peugeots are usually maintained by dealers here.
    I bought a 2004 407 2.2 petrol with ~150K on the clock.
    The log book has records up to 98K (and none of them has any comments). And now the car says that it was due for a service 51 000 ago. Which probably means that it wasn't serviced at Peugeot dealer since then.
    Running VIN against PSA database reveals dealer service records up 44 000.
    My question is, what are the chances that timing belt has ever been done?
    The previous owner is far from mechanically minded so of no help.
    Don't remind me!
    16,609
    If you don't know, err on the side of caution. Petrol engines in this family are expensive if there are meetings between valves and pistons.
    pug206gti likes this.
    SWOTR
    3,627
    Yes, unless you have positive proof that the timing belt has been done, assume it hasn't.
    Feb 2016
    38
    Yep, that pretty much what I was thinking. And that leads to the next question, what are the recommended mechanics to do that? What kind of price am I looking at?
    8,426
    Quote Originally Posted by warsch View Post
    Which leads on to the next question….what else should be replaced whilst they are at it??
    Jo
    Feb 2016
    38
    Jo
    I believe I know the answer to this one: aux belt, all the tensioners, water pump.
    Oct 2014
    Brisbane/Australia
    387
    Only place I know of in Brisbane is DS Motors. They know these cars like the back of their hands. They're great on price too. I have no experience with PSA petrol engined cars, so can't help on price.
    Like the others have suggested, err on the side of caution and get it done. It doesn't mean the car hasn't been serviced for 50,000 kms just that the service indicator hasn't been reset since then. Probably the same professional mechanic who didn't plug in the abs sensor when changing fuel pump.
    Feb 2016
    38
    Quote Originally Posted by dcc236 View Post
    Thanks, will give them a call.
    I understand, but the fact it hasn't been reset probably means that all the services after 100K were just oil changes.
    Sep 2003
    North Parramatta
    3,997
    At that age and mileage, it should have already had two belt changes and is ready for its third, based on the Peugeot Australia 4yrs/80k schedule
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    UNM
    UNM is offline
    Dec 2014
    Melbourne, Australia
    318
    I don't know that 2.2 engine specifically, but both the 1.6 TU5 and 2.0 EW10 engines I have replaced timing belts on were incredibly easy to do. The tight space on the 206 GTi with the EW10 made removal of the cover and access to the tensioner a bit tricky, but still easy to do in a couple of hours at home.
    I did not bother with the water pump as it is easy enough that I can treat as fix on fail. If I was paying a garage though, it is worth the extra cost to get it all done at the same time - if you don't know enough to do the job yourself (or don't want to), then it is best to have that peace of mind and save two trips to a mechanic.
    Feb 2016
    38
    Quote Originally Posted by SLC206 View Post
    I highly doubt there was a second belt change. And that was pretty much my question. But I guess it's due for replacement anyway.
    Feb 2016
    38
    Quote Originally Posted by UNM View Post
    Yeah, it seems like a kind of job I can do myself. 407 with 2.2 has enough space under the hood.
    My google finding show that pump bearing failure can cause the belt to skip or go off. And I don't feel like doing the same job twice even if I do it myself for free. Pump isn't that expensive anyway.
    Sep 2003
    North Parramatta
    3,997
    I'm a bit leery about changing belts just on time, but as has been mentioned if you don't have any history it's better to err on the side of caution.
    Simon
    Feb 2016
    38
    It seems to be a job a can do myself and all the parts cost like $250-300. So I'll sure do that in the near future.
    Mar 2011
    Kendenup WA
    124
    Anyone that buys a second hand car, especially one without an up-to-date service record, should, for peace of mind and reliability, give it some serious preventative maintenance. I recently bought a 5 year old SUV which had a slightly dubious service record covering the last 18 months. Because of this, and also because I live on a farm far from garages I did the following:
    Changed all the oils; the brake and clutch fluid and the coolant. Replaced all the filters, including the fuel. New s/plugs. Checked the brake pads. Fitted new wiper blade re-fills. Checked condition of vacuum and coolant hoses. Replaced the s/plug leads.
    Still to do: Fit new oxygen sensor and fan-belts.
    Luckily my SUV has a timing chain set-up. But in your case, whilst replacing the timing belt and w/pump, I would seriously consider replacing not only the tensioner assy, but also the seals for the camshaft, crankshaft and idler shaft.
    Sure it costs money and is time consuming -- but, if you can do most of it yourself, you'll be quids in front in the long run.
    Pavel
    Feb 2016
    38
    Quote Originally Posted by Pavel Moore View Post
    I agree with the first part, that some maintenance should be done on a newly bought used car. But I think changing seals that don't leak is an overkill. I am realistic - the car is more than 10 years old, I can't afford to change all the parts just for the piece of mind. The timing belt is a bit different, as its failure is fatal for the engine.
    8,426
    I too lean towards your way of thinking.
    I call it reactive maintenance…..If something is wrong, I react to it, and if I could be bothered…..fix it.
    I never go looking though.
    I always tell myself that the day everything on the (2002) car is fixed is the day a the universe craps on me and a bus runs into it and writes it off.
    When I took over possession of the car the timing belt was a day old, so that was no issue.
    Changed the fluids, replaced the front brake rotors and pads, rear shocks and a rubber drive thingy and have pretty much done nothing since except change the oil every 10k km and the tyres twice.
    Jo
