504 Ti running poorly
Results 1 to 18 of 18
Like Tree11Likes
  • 1 Post By GRAHAM WALLIS
  • 1 Post By BIGRR
  • 1 Post By ThanosK
  • 1 Post By BIGRR
  • 1 Post By dacia4x4
  • 1 Post By ThanosK
  • 4 Post By tonch504
  • 1 Post By tonch504
Thread: 504 Ti running poorly
    Slovenia
    198
    Default 504 Ti running poorly
    Hi All,
    My Ti was running well before I removed and refitted the cylinder head (don't ask why, that's a whole other story!). Now that I have refitted the head and the ancillaries the engine is running very rough. It is blowing black smoke and the exhaust smoke actually burns the eyes because of how rich it is running. The plugs are dry but quite black. And they are all the same.
    When I installed the distributor I didn't push it fully down and the engine turned over but the distributor was stationary. I also connected the coil reverse polarity.
    While trying to start the car the engine misfired or backfired a couple of times in a big way.
    What damage could I have done to cause this problem?
    Thanks in advance for any help you can offer.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,439
    Quote Originally Posted by tonch504 View Post
    Hi All,
    Are all the hoses on the inlet manifold correctly connected?
    Doubt you have damaged anything.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,258
    Sounds like a torn rubber diaphragm in the injector pump.
    FedGrapes likes this.
    Feb 2006
    North Rocks, Sydney
    2,439
    My 1st Thought too.
    Same thing would happen if the vacuum hoses to the top of the pump chamber are incorrect/reversed. Lets hope?
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    Slovenia
    198
    Thank for the advice.
    I have rechecked all the pipes and they seem fine. All in the correct location and in good condition.
    Where is the rubber diaphragm in the pump and is there a way to check it without taking the pump out?
    Have also swapped the coil and condenser. No change.
    Initially I thought it was running on 3 cylinders but removing one plug lead at a time changes the way it runs, so I suspect it's not running on 3.
    The exhaust makes a distinct pop, pop, pop noise?
    Greatly appreciate any further advice.
    Dec 2002
    Menzies Creek
    2,541
    Tappet too tight?
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    tweed heads
    1,496
    So suspect its not running on three cylinders, not no3, i had to read that twice myself,if the rubber diaphragm is what monitors air flow ,the back fire could have damaged or jammed it or the mechanism it operates to regulate the mixture causing it to run rich ,seems like you need to do some reading up on ti ,pugs
    Slovenia
    198
    Yeah that's right, sorry pugwash, it is running on all 4 cylinders.
    I guess it could be a tight tappet, but after setting them I went back over them and rechecked.
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,749
    In a 404 I would say it's the lever that connects the throttle body to the injection pump, but the 504TI has the diaphragm so I don't know...
    The problem does not sound consistent with head work, something is amiss with the injection.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    Dec 2011
    Athens, Greece
    299
    I also think it's injection related; torn membrane. There is no vacuum so it feeds fuel as if it is constantly at WOT. One way to check is to drive it at 5000-6000 rpm for a few minutes. If the black smoke is reduced and the car runs smoothly during this test, the membrane is torn.
    BIGRR likes this.
    Slovenia
    198
    Thanks guys. Car not registered, so difficult to take it for a drive to test. Rolly says it's the diaphragm. He's gonna sort it for me.
    Feb 2006
    North Rocks, Sydney
    2,439
    A 5 minute check that the "choke" atomiser at the end of the inlet manifold is operating correctly. May be worth the effort.(?)
    Fitting new membranes to the pump is not that bad of a job. Go slowly, mark, photograph and count the number of turns on all items removed. Fit the new membranes and put everything back together in the original places (Check, marks, photographs and number of turns etc) and "Bobs your uncle.
    Good luck.
    tonch504 likes this.
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    Apr 2014
    kilsyth (lower montrose) vic,
    213
    Hi tonch504,
    Just a thought regarding your comment about wiring ignition coil reverse polarity,have you checked the condition of ignition points contact face,spring tension of points (if have been overheated may reduce spring tension loss/reduction),condenser condition?All of these could cause weak spark,misfire,incomplete fuel burning,might be worth checking before delving into governor diaphragm/cold start choke/enrichener position. just a thought Jim
    BIGRR likes this.
    Slovenia
    198
    Thanks Jim,
    I swapped the coil and condenser but it made no difference. Removed the distributor and visually inspected it. I couldn't see a problem but I guess that is not a comprehensive test. I must say that as I was removing the spark leads one at a time the start which was jumping to the plug tubes was quite large. So I think the ignition system is is ok.
    Dec 2011
    Athens, Greece
    299
    The fact that there is an rpm drop as you disconnect each spark plug cable indicates that the problem is not electrical.
    Slovenia
    198
    All sorted. The small diaphragm was torn.
    New diaphragms fitted, plus a bunch of o-rings, should be like a new one.
    Thank you all for your help.
    Feb 2006
    North Rocks, Sydney
    2,439
    Should be smiling and have another trouble free 150,000kms or so.
    Where did you get the kit? $?
    Present fleet:-
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 69' 10
    Renault 71' 10s
    Slovenia
    198
    Supplied and fitted by Rolly Pym. I simply dropped off the part then picked it up and refitted it.
    BIGRR likes this.
