Peugeot 407 throttle body?
Results 1 to 25 of 29
Like Tree2Likes
Thread: Peugeot 407 throttle body?
    Member warsch's Avatar
    Feb 2016
    38
    Default Peugeot 407 throttle body?
    Hi everyone.
    The car's Peugeot 407, 2004, 2.2 petrol, EW12J4, ~150К on the clock.
    The car goes into limp home mode after starting. Shows Engine fault : repair needed on the dash and has the following error codes in the ECU:
    P1153 Throttle stop programming.
    P0123 Motorised throttle signal 1. Short circuit to positive or open circuit.
    P0121 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
    P1134 Throttle motor position sensor 2
    P1161 Throttle position check. / Throttle position captor, check. Coherence.
    I've checked the fuses, they're fine. Disconnected all plugs from the throttle unit, they look ok. Disconnected the battery.
    Am I right thinking I've got to buy a new throttle body? Anything else I should check prior to that?
    If I decide to turn to wreckers, what other model do have this engine/throttle body?
    Thanks.
    Sep 2003
    North Parramatta
    3,997
    It's entirely possible.
    Here's a disturbingly similar story on Peugeotlogic
    I'm reasonably certain that, sadly, the 407 was the only Peugeot/CitroŽn sold in Australia with that engine and therefore, that throttle body.
    If sourcing one from a wrecker, you're looking for a VIN with a 3FZ or 3FY in it.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Feb 2016
    38
    Thank you, I've seen that link already. And VIN tip is quite good though 2.2 petrol seem to be quite rare at wreckers. Unlike diesel ones that are everywhere.
    Sep 2003
    North Parramatta
    3,997
    The part number is 1636.15 by the way.
    It does appear that you can get them on eBay, and EAI here in Australia even have one on eBay.
    Simon
    Feb 2016
    38
    Yeah and there are plenty of them on eBay in UK. $400 shipped via DHL express (which is same 3 days as local AusPost). Not a big deal but I just want to ensure it's the unit itself, not not the loom or something like that. Hence the question.
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    628
    well well i have a complete 407 2.2 petrol wagon wreck here with a good throttle body. pm me if you want it sent up
    1000+ Posts Shobbz's Avatar
    Brisbane, Australia
    1,284
    Have you checked the coil pack thingy (sorry the description escapes me). I had similar issues and one of the plugs was not firing correctly, So i had to replace the whole unit.
    shobbz
    Previous
    2005 407 ST Exec
    1975 504 GL
    Feb 2016
    38
    Quote Originally Posted by Balki View Post
    Thanks mate. I'll check the loom and all related wiring and some other things over the weekend. But I'm almost certain I'll have to buy a new throttle unit and thus will contact you soon.
    Feb 2016
    38
    Quote Originally Posted by Shobbz View Post
    Did you also have a bunch of error codes related to throttle body? And how do I check the coils/coil pack?
    Armidale
    2,456
    You also got this error:
    Have you eliminated the TPS? I believe it's integrated into the throttle pedal, and can put car into limp mode if faulty.
    Alec
    Feb 2016
    38
    Not yet, I'm just getting some ideas for the weekend. How do I tell TPS issues from all the other stuff?
    Armidale
    2,456
    Sorry - I only know what I read on this forum . I know others have had problems with the throttle/accelerator pedal sensor (not just on 407s, but on Cit C5s I think), but I don't know how to test it or how to replace it.
    Alec
    Feb 2016
    38
    So I took the throttle unit off and low and behold, the gears are shattered (as per one the links above):
    Time to replace it.
    SLC206 likes this.
    Armidale
    2,456
    Well I'll be...
    Great diagnostic work! Hope the replacement isn't too expensive.
    Alec
    addo likes this.
    Don't remind me!
    16,609
    Seconded, thanks for posting up your findings.
    Oct 2014
    Brisbane/Australia
    387
    Is this for the car that was in Moggill?
    Jun 2011
    Ballarat
    537
    Hi - So I am interested in the cause of failure. I am thinking a back fire!!
    Feb 2016
    38
    Quote Originally Posted by dcc236 View Post
    Not exactly Moggil, but I guess it's that one, yes.
    Feb 2016
    38
    Quote Originally Posted by Whippet View Post
    This sort of failure seems to be fairly common. Plastic gears aren't really known for their durability.
    Sep 2003
    North Parramatta
    3,997
    As mentioned, thanks for posting up your findings. It will be a reasonably pricey fix, but hopefully it helps others too.
    Simon
    Feb 2016
    38
    Quote Originally Posted by SLC206 View Post
    New throttle body is 400 AUD shipped on eBay. And 15 minutes to install it back.
    Armidale
    2,456
    Ouch!
    Feb 2016
    38
    So I got a replacement throttle body (thanks Balki), installed it, then followed the procedure that supposedly initializes the throttle. And all's good.
    For anyone curious, this is the procedure found on the internet:
    1. Turn on ignition (do not start the car) for 30 sec
    2. Turn off ignition for 30 sec
    3. Turn on ignition (do not start the car) for 30 sec
    4. Turn off ignition for 30 sec
    5. Turn on ignition then slowly push the throttle pedal to the floor, kepp it like that for few seconds
    6. Turn off ignition
    7. Start the car
    Not sure if it works, but lot's of people claim it helps them with intermittent errors and issues.
    Oct 2014
    Brisbane/Australia
    387
    Quote Originally Posted by warsch View Post
    I was at KMJ Wreckers at Sumner Park earlier in the week picking up some interior trim pieces for my 407. They have a 2.2L petrol 407.
    What did you end up paying for the 407? I was going to go and see it as I live around the corner, but couldn't tee up a time with the woman. Is it a keeper or are you going to sell it?
    You can also use Lexia for throttle body alignment.
    Feb 2016
    38
    I wish I knew that earlier. But anyway sourced the part from this forum.
    $1400 plus towing. Also had to fiddle a bit with ABS sensor. "Professional" mechanic who replaced the fuel pump forgot to plug the sensor back in. I'll keep the car for my wife. It's in good condition though it would need a service and probably a major one.
    I'll probably do that once the car's back on the road.
