Peugeot 404 Ignition Switch Barrel Pic
Results 1 to 10 of 10
    Echuca
    104
    Default Peugeot 404 Ignition Switch Barrel Pic
    I've been carting around what I believe to be a 404 ignition barrel, new with key in a Silca branded box for more than 40 years. The silca key has A25 on it.
    Has anyone got a pic so I can confirm what it is?
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,321
    Mar 2013
    olinda victoria australia
    723
    Default 404 ignition switch
    Quote Originally Posted by Ropes View Post
    If it is a 404 original lock and key I would be interested in grabbing it, should you have no plans for it
    Have been generally dissatisfied with locks/barrels/keys from after market suppliers, especially those for the DS
    If you want to get rid of it , please send PM
    Best Wishes
    Andrew Watkins
    Echuca
    104
    Quote Originally Posted by IWS View Post
    I couldn't see any matches there. It shows mostly complete assemblies, not the inner bit.
    Echuca
    104
    Quote Originally Posted by Andrew Watkins View Post
    Best Wishes
    Andrew Watkins
    We need to work out what it is first.
    IWS
    IWS is offline
    Feb 2005
    Hawthorn East, Vic.
    1,321
    Maybe post a picture of it here and someone may be able to ID it?
    Echuca
    104
    I'd do just that if I had the means to it.
    IWS
    IWS is offline
    Feb 2005
    Hawthorn East, Vic.
    1,321
    Was not meaning to be a smart Alec with my suggestion - should have guessed you would post a photo if you could.
    Back to topic - sounds like you have just the lock barrel and the key - yes? (Not the whole ignition switch assembly).
    Ian.
    1000+ Posts Dano's Avatar
    Apr 2012
    1,245
    The following images are of a Siemens lock assembly out of the 404 owner handbook, is it similar?
ID:	80342Click image for larger version.
    Dan
    Echuca
    104
    It appears to be similar. Mine has 3 terminals - Bat, Coil and GA.
