205 GTi AirCon
Thread: 205 GTi AirCon
    Tadpole Super Josh's Avatar
    Jun 2003
    England
    28
    Default 205 GTi AirCon
    Guys,
    A few questions on 205 Aircon.....Is the under dash heater box different on the Aircon models? I realise it must have a drain foe the water, but is the fan located in it rather than in the passenger footwell? And where does the PAS pump go on and Aircon model.
    Josh
    Miami Blue 205 GTi limited edition with Skip Brown 1.9S conversion Full leather interior, Skip Brown phase 2 suspension, Quaife ATB LSD, Grp N mounts, Grp N Exhaust, GTi 6 Brakes running Mintex 1144's and Goodridge Braided Hoses. Emerald M3D ECU to come soon.......
    Dec 2002
    119
    Quote Originally Posted by Super Josh
    Guys,
    PAS pump goes underneath the alternator and above the aircon compressor on the auxillery drive belt. Unlike the PAS pump and alternator, which share a belt, the aircon compressor runs off a dedicated belt.
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Hey Josh... Welcome 2 the jungle.
    What ECU do u use on your car man?
    Jun 2003
    England
    28
    Quote Originally Posted by Luca
    Cheers for the welcome lads As for the ECU, I'm using standard at the moment, but will be installing an Emerald M3D which is one of the reasonable priced 3D mapped ECU available here in the UK. About 600 UK Pounds.
    I'll be using it with the following:.............
    crank angle sensor
    Throttle pot
    MAP Sensor
    Air Temp Sensor
    Coolant Temp Sensor
    Lamda Probe
    Coil pack
    Josh
