Removing front bumper on 205 GTI
Results 1 to 10 of 10
  • 1 Post By djvu205
Thread: Removing front bumper on 205 GTI
    Member VC205's Avatar
    Nov 2015
    95
    Default Removing front bumper on 205 GTI
    Hi all. This might seem like an obvious question but just wanted to check; to remove the front bumper of a 205 GTI, it would seem necessary to remove the wheel arch trims also in order to get access to the fixing bolts/screws. Is that right?
    cheers
    vic
    Nov 2012
    374
    From memory you don't have to remove the whole arch, just the front most mounting tab. Then you can carefully bend/manoeuvre it aside to get the bumper off.
    Fellow Frogger! dhaw's Avatar
    Feb 2005
    SYDNEY
    529
    Quote Originally Posted by VC205 View Post
    cheers
    vic
    Just been playing with the 306... this might help you.... I'd guess yes! Peugeot 205 - Bumpers - removal and refitting - Bodywork and fittings
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,052
    Nice thread, just what I'm doing next! cheers...
    how did you go Vic?
    Nov 2015
    95
    Quote Originally Posted by CEyssens View Post
    how did you go Vic?
    I didn't get around to it yet but I think I will probably take the wheel arches off mine first anyway.
    1000+ Posts Richard W's Avatar
    May 2012
    1,355
    Vic - to take the front arch off fully you will need to remove the little red inserts. I can never manage this without bending them, and they are now almost unobtanium. I wouldn't take the arch trim off until you are ready to do the respray.
    Sent from my Q10 using Tapatalk
    1000+ Posts djvu205's Avatar
    1,402
    The red metal trim comes off easy once you get it going permitting that someone hasnt put the retaining clips on upsidedown. Flick the top part of the strip out first then the bottom should come out. If you bend them slightly or need to get dents out rub them with a piece of wood on a good clean flat surface. The worst part is the clips the hold the plastic trim on they always break and the clips are hard to get off.
    CEyssens likes this.
    Nov 2015
    95
    Thanks for the tip for the red trims. I will let you know how it goes.
    Jan 2016
    Berwick VIC AUS
    1,052
    Hi, I was able to remove my front bumper this evening, the main hurdle I had was the wheel arch plastic trim. I only removed the front three clips and the trim easily came away enough to remove the bumper.
    But those clips were a pain. The first two that go through the end of the bumper were the worst and I ended up clipping them off with aviation snips so that I didn't break the plastic lugs. the next one that went through the guard wheel arch came off pretty easily.
    Fellow Frogger! le frogg 205's Avatar
    canberra city australia
    394
    im going to try to make mine bolt on. maybe epoxy some small bolts into the plastic tabs and use nuts with washers to fx to the car. just a thought.
