206 air con intermittent
    Jun 2004
    156
    Default 206 air con intermittent
    Borrowed daughter's 206 for a summer trip to ballarat. A/C seemed to take 5 or so minutes to get going on the trip, was working well, then seemed to expire half-way to ballarat. Local A/C man in Ballarat suggested refill (my thought too just to exclude other causes). Got it recharged (it had lost 20%, apparently). Subsequent use was good, but occasionally (again) seemed not to work. Problem "solved" by turning the fan switch OFF then ON again maybe more than once. When working, which was most of the time, worked well. Any thoughts?
    Don't remind me!
    16,609
    Possibly the solid state clutch relay. Suggest fitting a helper relay for the AC clutch in the engine compartment soon as you are able.
    1000+ Posts driven's Avatar
    Apr 2005
    1,479
    Daughter had same issue with her 206Gti. Compressor is on the way out.
    Had to replace entire unit
    Don't remind me!
    16,609
    That may have been a different problem. I'd suggest my relay fix first, it's a $25 DIY project and even with a new compressor, helps the system.
